jp7179 Posted September 7, 2010 Share Posted September 7, 2010 my car had a flat tire the other day and picked up some new rims.. and my tire pressure monitor lights are on.. i checked the pressure and everything was fine.. help?? does the rims matter?? Link to comment Share on other sites More sharing options...
jp7179 Posted September 7, 2010 Author Share Posted September 7, 2010 http://i304.photobucket.com/albums/nn164/jp7179/car/2caa2807.jpg http://i304.photobucket.com/albums/nn164/jp7179/car/40b393a7.jpg Link to comment Share on other sites More sharing options...
dmanaenk Posted September 8, 2010 Share Posted September 8, 2010 Did you move the sensors from old to new wheels? 666 Link to comment Share on other sites More sharing options...
pillboy Posted September 8, 2010 Share Posted September 8, 2010 You have to move the old air into the new rimz. The monitor is synced with the old air. I hope you saved it. It is still ugly. Link to comment Share on other sites More sharing options...
vr4Legacy Posted September 8, 2010 Share Posted September 8, 2010 on a serious note.... Do the new rims have TPMS sensors in them? If so are they the old ones or replacement ones? If they are new, you will have to pay Subaru to reset the sensors to your new ones. If they are the old ones, my guess is the tire shop broke one switching them. If you didn't get new sensors, find a pretty little decal and place it gingerly on your dashboard as to obscure the pesky light. IMHO it's pointless anyway as it alerts you too often and is very tempermental, leaving you not trusting it, so if it were to go off chances are you'd just ignore it anyway. Use your sense and look at your tires regularly and check the PSI occaisonally. Link to comment Share on other sites More sharing options...
SpecBGuy Posted September 8, 2010 Share Posted September 8, 2010 isnt here a wire you can cut or bypass you can do to turn the light off? Link to comment Share on other sites More sharing options...
jp7179 Posted September 9, 2010 Author Share Posted September 9, 2010 thanks guys.. but i do have a question.. i need the old air?? or do you just mean remove the old sensor from the old rims and putting it into the new one?? Link to comment Share on other sites More sharing options...
Draco-REX Posted September 9, 2010 Share Posted September 9, 2010 thanks guys.. but i do have a question.. i need the old air?? or do you just mean remove the old sensor from the old rims and putting it into the new one?? THe old air response was a joke. You do need to move the TPMS sensors to the new wheels. Your car is expecting a sensor in each wheel to report what the pressure is. With those missing, your car will turn the light on since it doesn't know what the tire pressures are. If you move the old sensors to the new rims, the light will go out after a while. Thing is, the tire shop you got the rims and tires from and mounted should have told you about the TPMS sensors. They're not exactly a unique feature to Subarus. Link to comment Share on other sites More sharing options...
biodtl Posted September 9, 2010 Share Posted September 9, 2010 The sensors are likely still attached to the valve stems of your old rims, the shop should have recognized that. If you still have your old rims, have a look at the valve stem on the inside of the wheel, they are pretty obvious. If they are still on the old wheels, the shop will have to remove and remount your tires to install the sensors. Don't let them try to charge you anymore to do that. FYI, I did have to drive my car about 10 miles before the TPMS light went off after installing the old sensors on new wheels. Link to comment Share on other sites More sharing options...
