klm1 Posted September 1, 2010 Share Posted September 1, 2010 Do they make these rotors? If they make them a) who makes any b) advantages/disadvantages? Do they make a them for soobie's? Link to comment Share on other sites More sharing options...
Scooby Fan Posted September 1, 2010 Share Posted September 1, 2010 No aluminum rotors...they would be way to soft. Carbon fiber is the way to go for those with truly unlimited bucks. Link to comment Share on other sites More sharing options...
Malt Beverage Posted September 2, 2010 Share Posted September 2, 2010 There are two piece rotors that are partly made of aluminum, specifically the rotor hat. No real benefit I could think of on a LGT, unless your wallet is a little to heavy/thick . Link to comment Share on other sites More sharing options...
Malt Beverage Posted September 2, 2010 Share Posted September 2, 2010 http://www.racingbrake.com/LEGACY_2_5_GT_FRONT_05_06_p/2020-311.htm Link to comment Share on other sites More sharing options...
praedet Posted September 2, 2010 Share Posted September 2, 2010 A 2-piece rotor with an aluminum center hat will cut the weight of the rotor to 2/3-1/2 of the original weight... It has the same benefits as lighter rims and tires for handling and acceleration. Carbon Ceramic rotors are even lighter... Link to comment Share on other sites More sharing options...
Max Capacity Posted September 2, 2010 Share Posted September 2, 2010 Man, that's so worth it for the weight savings on your wallet. I say, you should do it. I'm your'll notice a big difference the way the car drives. Don't forget to buy light weight wheels too. Oh, Welcome to the forum... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
