Kw521 Posted September 1, 2010 Share Posted September 1, 2010 Its time for me to change the tranny/diff fluids in my car. I have heard from a tuner around my area that running synthetic in the sti/6spd transmission they always had problems with it and they would blow. Well I have the 5MT. Anyone else here using synthetic gear oil? Or should I just use the traditional 90W regular stuff? Link to comment Share on other sites More sharing options...
Max Capacity Posted September 1, 2010 Share Posted September 1, 2010 Hey I was AF too. Years ago. Go the the Vendor Fred Beans, call them and order Subaru Extra-S don't waste yourtime with anything else. It's like 12.00 a quart. But it's what most here will tell you to use. It's 75w-90. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
GTTuner Posted September 1, 2010 Share Posted September 1, 2010 Beans won't sell quarts anymore. I just used Mobil 1 75w-90 synthetic LS. Shifts like butter. I had 75w-140 before, it did not shift as nice even hot. Link to comment Share on other sites More sharing options...
RedDawg Posted September 1, 2010 Share Posted September 1, 2010 i put in redline synthetic about a month ago because i couldnt find extra-s anywhere. I'm happy with the results, i would recommend it. Link to comment Share on other sites More sharing options...
ehsnils Posted September 1, 2010 Share Posted September 1, 2010 Beans won't sell quarts anymore. I just used Mobil 1 75w-90 synthetic LS. Shifts like butter. I had 75w-140 before, it did not shift as nice even hot. The 140 is probably too thick for the gearbox. Save that for those straight-cut and unsynchronized gearboxes that you may find in some odd older tractors. Not that the 140 will do any damage to the gearbox, it's just that the gearbox isn't really designed for it. OK, if you happen to live in Death Valley the 140 may be fine. Just check that the oil is suitable for LSD diffs, some oils have additives that are bad for the LSD diff package. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 1, 2010 Share Posted September 1, 2010 Beans won't sell quarts anymore. I just used Mobil 1 75w-90 synthetic LS. Shifts like butter. I had 75w-140 before, it did not shift as nice even hot. That's bummer, I just bought some 8 weeks ago. Oh god it's true, I just received a email from Jeremy They do sell redline on the site. I'll fess-up, I do have redline in my rearend... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
spartan Posted September 1, 2010 Share Posted September 1, 2010 Is there any where to get quarts of the extra s anymore? Link to comment Share on other sites More sharing options...
Scooby Fan Posted September 1, 2010 Share Posted September 1, 2010 I've been using Redline since the car was new.....awesome stuff. Link to comment Share on other sites More sharing options...
Kw521 Posted September 1, 2010 Author Share Posted September 1, 2010 well i went to the dealership today to ask about getting my diff fluids changed as well as my transmission fluids changed too. 300 bucks!?!?! wtf?! Is it that complex or are the just raping me without lube? Link to comment Share on other sites More sharing options...
RochNY91TSI Posted September 1, 2010 Share Posted September 1, 2010 ^^Raping... It's a half hour job at most, especially with the car on a lift Link to comment Share on other sites More sharing options...
Kw521 Posted September 1, 2010 Author Share Posted September 1, 2010 F that! I've never changed the diff/transmission fluids...is it the same as oil change? A drain plug and filling it back up? If so we have a lift I can use on base around here and ill do it myself Link to comment Share on other sites More sharing options...
ehsnils Posted September 1, 2010 Share Posted September 1, 2010 Same as oil change except that you don't have any filter to change. May be a bit more tricky to fill up the oil but nothing that's extremely hard and most transmission fluid bottles do have a special pipe/hose for it these days. If not just a piece of plastic hose (around 8 to 10mm outer diameter) and a drill of the same size, drill a hole in a cap and pull the hose through with a tight fit and you have a filler cap for transmission fluid. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 1, 2010 Share Posted September 1, 2010 Yea the auto hobby shop will have the suction gun or long funnel for you to use. Hint on the tranny oil, you need to have the rear of the car higher then the front to get all the old stuff out. 5 quarts will do both. Make sure they have 50 or 60 torqx bit for the tranny plug. The rear diff is a 1/2 drive. Hey, we don't call them stealerships for no reason. Did you ask them if that price comes with a Happy ending 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Kw521 Posted September 1, 2010 Author Share Posted September 1, 2010 /\/\/\ LOL! This guy was a retired master sergeant. I went there in uniform. I figured he'd have hooked it up. Guess not Link to comment Share on other sites More sharing options...
Scooby Fan Posted September 1, 2010 Share Posted September 1, 2010 I had all mine done a while ago....oil change...diff....and gearbox at my dealer....$86...I provided the Redline lubes....you are getting F***ed. Link to comment Share on other sites More sharing options...
Kw521 Posted September 2, 2010 Author Share Posted September 2, 2010 WTF!?! /\/\ is your car under warranty though? Link to comment Share on other sites More sharing options...
Scooby Fan Posted September 2, 2010 Share Posted September 2, 2010 I don't think any "Fluid changes" are warranteed...I just took the new oils in when it was due for a service and asked them to do the change. Took less than an hour so it was all labor since I provided the fluids Link to comment Share on other sites More sharing options...
Whatisit Posted September 2, 2010 Share Posted September 2, 2010 http://mgmotorwerks.com/images/website%20005.jpg i was able to find this stuff locally. put it in my 6mt bee, and now she shifts smoother then silk. no gear noise or whine either. Lubro-Moly got fairly good reviews on BITOG. comes as factory fill on most german cars (Porsche, BMW, and Audi) Link to comment Share on other sites More sharing options...
05LGTLtd Posted September 2, 2010 Share Posted September 2, 2010 Extra-S is the schiznet. If you can't get quarts find quarts, just GB a 5gal with a couple of locals and split it out. If you have any local independent shops that specialize in subaru they may have it on hand and could either sell you what you need or do the service for a reasonable rate. All I need now is a hill holder and a center passing light... Link to comment Share on other sites More sharing options...
mightyS Posted September 2, 2010 Share Posted September 2, 2010 I had a shop put in some synthetic 70w-90 gear oil in. The same day, I started getting a gear grind when shifting from 3rd to 4th under boost. The other gears seemed to shift fine. I found on the WRX page that this is common and it goes away if you use the Subaru extra S gear oil. I bought the gear oil from a dealership in LA and the gear grind went away! I had the gear oil change at a local speed shop and they charged $20. I can't believe that a dealership wants $300. Here is where to find Extra S gear oil. This Subaru dealership in LA has it. http://forums.nasioc.com/forums/show....php?t=1946774 Link to comment Share on other sites More sharing options...
Kw521 Posted September 2, 2010 Author Share Posted September 2, 2010 Looks like Ill be using redline. But there is no way I am going to have that dealership do that! I will do it myself for that much money or I will ask a different place and see what they charge cause that is royal rape. Link to comment Share on other sites More sharing options...
Kw521 Posted September 2, 2010 Author Share Posted September 2, 2010 I also noticed on the redline website that they have different oil for diffs and transmissions? Will i need to get those both or does one work for the diffs and trans? Link to comment Share on other sites More sharing options...
notthesnail Posted September 2, 2010 Share Posted September 2, 2010 Amsoil Severe Gear is nice stuff. 75W90 or 75W110 will work for both diff and trans. You'll probably want a pump for the refill. Your Amsoil guy can get you one that fits the bottles for around $10. Link to comment Share on other sites More sharing options...
Kw521 Posted September 2, 2010 Author Share Posted September 2, 2010 Will the red-line fluids work the same? or do i need separate ones? Link to comment Share on other sites More sharing options...
