Heedz Posted August 25, 2010 Share Posted August 25, 2010 How does the wiring harness work? If i get one form an audio store doesn't that take power away from the AC control unit also? How can i keep the climate control powered? I do not care if the stereo part works. Please help, I've been searching but I cannot find a definite solution. Link to comment Share on other sites More sharing options...
SVXdc Posted August 25, 2010 Share Posted August 25, 2010 Yes, you do have to keep the power wires connected to the OEM stereo -- that also powers the A/C control panel (because the radio and automatic A/C panel are really one big, combined unit). You'll need both a "forward" and a reverse 14-pin harness. You'll wire those together along with the harness for your aftermarket stereo (making a Y-harness), wired as follows: * Both stereos will get ground, +12V Battery, and +12V Accessory from the car * The car's speakers and antenna remote control (from the forward harness) will only connect to the new stereo * The speaker outputs and antenna remote control output from the OEM stereo (from the reverse harness) will be unused (cap off with heat shrink or electrical tape) * Illumination and Dimmer will go to the OEM stereo * Illumination will also go to the new stereo (if supported) Also, the car's coax antenna wire will only connect to the new stereo, through a Subaru antenna adapter. Optionally, you can connect one pair of the factory stereo's speaker outputs through a Line Output Converter (LOC) and into an Aux input on your new stereo. That will allow you to keep using the OEM 6-disc changer (and sat radio and factory aux input on newer models, if you have those). Make sure the harnesses have all 14 pins/wires. Many of the ones out there omit the Orange/White dimmer wire at pin #7. Without that, the OEM A/C panel's illumination won't work correctly when you turn on your headlights. See my Legacy/Outback radio harness pin-out table for more information (including link to harnesses guaranteed to have all 14 wires). Link to comment Share on other sites More sharing options...
christurismohk Posted August 25, 2010 Share Posted August 25, 2010 here's my install: http://legacygt.com/forums/showthread.php/clarion-vz509-single-din-navi-and-backup-cam-installed-122958.html?t=122958 You need the harness from David Carter Link to comment Share on other sites More sharing options...
