Theride Posted August 25, 2010 Share Posted August 25, 2010 Will the stock strut/shock gets softer over time? I just feel they dont absorb rough road/bumps properly. You also hear thing pong sound when over rough terrain. Link to comment Share on other sites More sharing options...
boymk123 Posted August 25, 2010 Share Posted August 25, 2010 Will the stock strut/shock gets softer over time? I just feel they dont absorb rough road/bumps properly. You also hear thing pong sound when over rough terrain. yes, they do wear out but it takes a while Link to comment Share on other sites More sharing options...
Theride Posted August 25, 2010 Author Share Posted August 25, 2010 any better replacement out there? like a softer shocks... Link to comment Share on other sites More sharing options...
Max Capacity Posted August 25, 2010 Share Posted August 25, 2010 Sounds like you just looking for a oem style replacement, not a performance set up. Just go the Sear's or any auto repair shop and tell them you want to shocks replaced. They will install whatever they have on the shelf. Lot's of common shock manufactures make replacements. If you looking for performance check out the suspension forum below. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
