Strizzy Posted August 21, 2010 Share Posted August 21, 2010 I am having a new shortblock built, as my #4 ringland bit the dust. I am looking to get around 350-375 whp out of my setup and was wondering if aftermarket headers will make a big difference over stock if going with a 18g or 20g (haven't decided on turbo yet). I would be getting Tomei headers. Is it worth the cost? Or would the money be better spent elsewhere? Thanks, Steve My bad luck build Link to comment Share on other sites More sharing options...
LittleBlueGT Posted August 21, 2010 Share Posted August 21, 2010 I am having a new shortblock built, as my #4 ringland bit the dust. I am looking to get around 350-375 whp out of my setup and was wondering if aftermarket headers will make a big difference over stock if going with a 18g or 20g (haven't decided on turbo yet). I would be getting Tomei headers. Is it worth the cost? Or would the money be better spent elsewhere? Thanks, Steve Headers make it more efficient, but whp/dollar are a pretty low mod IMO. And I have had a few on my car. If you want the widest power curve as possible, and want slightly lower EGTs (especially if on the track) then headers are a good bet. You will need something bigger then a 18g or 20g to get 350-375 whp on most set-ups. edit: I see form another thread that you will be running E85, in that case you may just get your power goals, but 20G is a no-brainer, especially with the lower end power you get with E85. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted August 21, 2010 Share Posted August 21, 2010 20G is a no-brainer, especially with the lower end power you get with E85. x2 Link to comment Share on other sites More sharing options...
mwiener2 Posted August 21, 2010 Share Posted August 21, 2010 GrimmSpeed headers and crossover. Best bang for your buck for headers. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Strizzy Posted August 21, 2010 Author Share Posted August 21, 2010 Thanks for the info. I guess I can hold off on the headers for now then, and put that money towards the turbo. Headers are an easy enough install anyways and aren't a critical part of the build. With that said, I will be going with the 20g. Thanks again. My bad luck build Link to comment Share on other sites More sharing options...
