proflatlander15 Posted August 16, 2010 Share Posted August 16, 2010 Does anyone have a problem with their diff/transmission dip stick popping out after a while? Every few weeks I have to push the dipstick back in about a half inch. There is no sign of leaking, but is it possible the fluid is overflowing and pushing the dip stick out a bit? Link to comment Share on other sites More sharing options...
bluesuby Posted August 16, 2010 Share Posted August 16, 2010 My recollection is there's a spring device near the top of the stick which holds it firmly in the tube. Maybe you want to check if it needs a little bending to produce more tension. Link to comment Share on other sites More sharing options...
proflatlander15 Posted August 17, 2010 Author Share Posted August 17, 2010 I'll check it out. When I push the dipstick back in it is a snug fit, but apparently it's not enough. Thanks for the idea. Link to comment Share on other sites More sharing options...
