ssaldana Posted August 8, 2010 Share Posted August 8, 2010 Fellow owners, I'm having an issue with my 2005 Legacy GT. Problem: I started my drive from North Carolina to New York City and noticed that there was a slight loss in compression after 2500 RPM. Over the course of 7 hours in transit, the compression got worse. When tapping and holding lightly on the pedal, the car is fine and accelerates slowly. When pushing the pedal down moderately or all the way to the floor, the RPM needle jumps and keeps going to redline. During this process there is still some acceleration, though very slow. Half way in to the drive I heard a faint whistle where the volume level of this whistle was dependent on the Engine RPM. The faster the RPM, the louder the whistle. This lasted for 7 minutes. The car is driveable only if I push the pedal down lightly. Please help! Link to comment Share on other sites More sharing options...
ssaldana Posted August 8, 2010 Author Share Posted August 8, 2010 btw, no CEL. Link to comment Share on other sites More sharing options...
RabidWombat Posted August 8, 2010 Share Posted August 8, 2010 Manual or automatic? It could be an issue with the transmission not engaging properly. I had a similar experience with a friend's Mazda. Link to comment Share on other sites More sharing options...
bluesuby Posted August 8, 2010 Share Posted August 8, 2010 I would check for a leak or a loose intake plenum. If the engine is sucking air after the MAF sensor it'll upset the fuel/air mix (and probably whistle too). Link to comment Share on other sites More sharing options...
ssaldana Posted August 9, 2010 Author Share Posted August 9, 2010 Rabid, Manual Trans. bluesuby, I'll mention that possibility to Subaru tomorrow. Other things I neglected to mention... I just had maintenance done before the problem: Oil Change Oil Filter Air Filter Cabin Filter All Fluids Didn't think that would affect this but just throwing this out there just in case. Any more thoughts anyone? Link to comment Share on other sites More sharing options...
ssaldana Posted August 19, 2010 Author Share Posted August 19, 2010 Okay, problem solved. The clutch needs to be replaced. Link to comment Share on other sites More sharing options...
