dmanaenk Posted July 22, 2010 Share Posted July 22, 2010 So if I lower the car half an inch more in the front than in the back, the oil dipstick will read higher oil level than there's actually in there? Any idea by how much more? 666 Link to comment Share on other sites More sharing options...
bluesuby Posted July 22, 2010 Share Posted July 22, 2010 Why don't you just scribe a new mark on the dipstick? You can change the oil and filter adding the correct amount of oil and make your full mark appropriately. Link to comment Share on other sites More sharing options...
BAC5.2 Posted July 22, 2010 Share Posted July 22, 2010 Pull off the oil pan, take some measurements, and find out! Its just math! But really, just make sure it's full. Swap the suspension, check the oil, and scratch a new line on the dipstick. Or... Leave it alone. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Max Capacity Posted July 22, 2010 Share Posted July 22, 2010 I'm betting you won't notice a difference. If any it will be very small. I wouldn't worry about it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Norm Peterson Posted July 23, 2010 Share Posted July 23, 2010 Rough estimate without crawling down underneath or actually measuring anything . . . so feel free to add any corrections to what are only guessed-at numbers Half an inch in not quite nine feet of wheelbase is a little less than a sixteenth of an inch slope per foot. I like 1/16" because it's conservative and makes the next step easier so that's what I'm going to use. Let's say the sump is one foot long (front to back in the car) and rectangular. Oil depth would be about 1/32" deeper at the front and about 1/32" shallower at the rear than it was before. If the sump is shorter than one foot long, it'll be less than 1/32" change. Your call as to what to do. How good are your eyes and how consistently do you think you're able to make the readings? Norm Link to comment Share on other sites More sharing options...
Max Capacity Posted July 23, 2010 Share Posted July 23, 2010 Let's not forgot you would need to have the car parked on a perfectly level ground for all that to really be correct. IMO it's to small to worry about. I thinks it's much more important to use the exactly right oil. We haven't had a good, which oil do I use thread on a few weeks now....LOL BTW Norm, thanks for your input on this site, I see your new, but seem to have a pretty good clue... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Norm Peterson Posted July 23, 2010 Share Posted July 23, 2010 Thanks for the kind words, Max. New to Subarus anyway, and I guess I'd better pass any credit over to some "Osmosis" guy. Norm Link to comment Share on other sites More sharing options...
