Al Thomson Posted July 14, 2010 Share Posted July 14, 2010 Anyone know the service interval on this? My local dealer was cluless when i asked them, "It's the same stuff as teh brakes use and you keep telling me how that absorbs water" i told him..... Link to comment Share on other sites More sharing options...
Max Capacity Posted July 14, 2010 Share Posted July 14, 2010 6 years on my fluid, still works fine. If it ain't broke don't fix it. Same with my brake fluid. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted July 14, 2010 Share Posted July 14, 2010 Hey, wait a minute....You don't beleive everything the stealership tells you do you...? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted July 14, 2010 Share Posted July 14, 2010 Remember...they are there to make money....not save you money ! 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Al Thomson Posted July 14, 2010 Author Share Posted July 14, 2010 You would think they would have a line about teh Clutch and how much they can make out of you for it. Link to comment Share on other sites More sharing options...
