SubaruFanatic Posted July 16, 2010 Author Share Posted July 16, 2010 I have money that says anyone who breaks a PPG set had them incorrectly installed. Or they didn't know how to drive. And I hate to break it to you but a 6spd swap is easily 3-4K more when done correctly. Between a used trans, axles, rear diff, new clutch, flywheel, and misc. it's a lot more. will a stock clutch not fit up to the 6mt tranny? i'm going to be putting in a new clutch this week. Also does anyone know the gear set ratio on the 6mt? I believe that 5mt is 411 correct? Link to comment Share on other sites More sharing options...
SubaruFanatic Posted July 16, 2010 Author Share Posted July 16, 2010 i was reading the master 6mt swap in the tranny section.... it seems like it might be easier just to swap gear sets and go to a 3.90 or something... I would like a 6 speed but if its going to cost near 4 grand its not worth it. Link to comment Share on other sites More sharing options...
thebootyhouse Posted July 17, 2010 Share Posted July 17, 2010 will a stock clutch not fit up to the 6mt tranny? i'm going to be putting in a new clutch this week. Also does anyone know the gear set ratio on the 6mt? I believe that 5mt is 411 correct? You need a clutch for a 6MT. The 5MT clutch will not work. Not sure of the 6MT final ratio? Correct, 5MT final ratio is 4.11. Link to comment Share on other sites More sharing options...
andrew vento Posted July 17, 2010 Share Posted July 17, 2010 i just fried my stock clutch the car has 91000 miles on it, its an 05, i an a dual xo2 exhaust, catless downpipe, catless uppipe, k&n typhoon intake system. kart boy short shifter, ej257 intake manifold, 70mm throttle body, and stock turbo tuned to 17psi, i need a new clutch kit and new flywheel i was looking at the spec stage 2plus and aluminum flywheel, i figured $1000 not too bad because its my daily driver and im low on cash. also what size injectors should i put on? and what kind of fuel pump? thanks. I found a 5mt out of a 2002 wrx that needs rebuild. I am worried I will break my tranny because of power and the way I drive. So I was wondering if a 2002 5mt would fit an 05 lgt first off and second, could I also make this a 6speed? Anyone know who does them? Link to comment Share on other sites More sharing options...
SubaruFanatic Posted July 17, 2010 Author Share Posted July 17, 2010 You need a clutch for a 6MT. The 5MT clutch will not work. Not sure of the 6MT final ratio? Correct, 5MT final ratio is 4.11. oh that would figure that it wouldn't work..... like i said before maybe i'll just change the gear ratio. I'm not going to but this new clutch use it for a little then swap to a 6 speed and do the clutch all over its to expensive.. Guess I'll just stay were i'm at for now. Link to comment Share on other sites More sharing options...
