USB kill switch
fishbone
Posted
I'm sure I'm not the first that is bothered that the Accessport continues to be powered on when the vehicle is shut down. Has anyone found or made the corresponding USB cable with an on/off switch?
Posted
It should be easy. USB is 4 wires. One is + one is - for power, the other two are I/O wires. Just wire up a mini relay powered by 12V ign-on, and call it good. AP turns on when key is ON, turns off when key is OFF. Use fuse #26 for the power (ignition #2/Unit). That way it will get constant power once in the ON position, but no power in the ACC position.
You could even have a manual override built into this.
[URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard
Posted
Sure you can do that but the dongle is what is supplying the power to the AP. So what you really need is to switch the power at the ODB-II port. Just install the switch in the car side wire of pin 16. Or even remove that wire and take power from an ACC line and connect it to pin 16. Then the ODB-II port (and anything plugged into it) will only run when the ignition is ON or ACC.
Posted
The idea is sound, the application a bit troublesome for me. I'm going to have to go identifying which wire is which. I definitely like the idea of cutting power to the OBDII port better.
Posted
ACC power cuts off during starting. IGN is on only in the ON position, and doesn't cut off when cranking.
BUT, there are plenty of times, for diagnostic purposes, where you would want the OBD port to have power when the vehicle is in the OFF position.
I'd make a USB cable with IGN on/off functionality, along with an override for times when you want the AP to be on with the car in the off position. That way you aren't LOSING any functionality, only adding it.
Posted
I think that might be model year dependent. There are ACC lines on the 05/06 that do not loose power on cranking. One of them is to the info panel.
What can you do through the ODB port when the power to it is off?
As an option then a two way switch could be used.
Position 1) power from battery to pin 16
Position 2) power from acc or ON to pin 16
Or this could be simulated with a relay control and a switch.
The relay contacts would go between battery and pin 16. The control of the relay could be supplied from acc or ON. If you need power when the car is off a switch could be used to supply the relay with power from the battery, otherwise it would be off for normal operation.
Posted
Since I know you like playing with hardware, what do you think?
http://legacygt.com/forums/showthread.php/usb-kill-switch-141199.html
Hmm... Interesting. If you're just trying to put an on-off switch on a USB plug the DIY is pretty simple.
The USB plug has 4 wires. The two wires on the end are + voltage (Red) and - voltage (Black). Pick which one you want to put a switch on, and solder a micro SPST switch on there with some heat shrink to protect the solder joints.
http://www.radioshack.com/product/index.jsp?productId=2062503
Just make sure not to put much stress on the switch. Its best to zip tie it to something or tape it to the rest of the wire to keep it from moving around. You don't want the solder joint to break.
Or you can use the relay mentioned earlier. Use both in conjunction to make a manual override.
Good luck! :)
  • 2 weeks later...
Posted
Just realized I never posted the pics of this, I did it a few days ago and it worked great! Red wire is all you need to splice in the USB cable, here are some pics, I installed the switch under the mute button for my radar now, looks great!
http://i626.photobucket.com/albums/tt344/docholladay23/USBSwitch1.jpg
http://i626.photobucket.com/albums/tt344/docholladay23/USBSwitch2.jpg
http://i626.photobucket.com/albums/tt344/docholladay23/USBswitch4.jpg
Posted
VERY nice! What mount are you using? I tried a bunch of phone holders ones, I like NONE of them because they are way too bulky. I am OK with using velcro, I just need some sort of plate to keep it held in place in the vent or somewhere non-intrusive.
Posted
I don't understand why you'd want to keep the AP hooked up in the car all of the time.
Posted
You know what, I remember now I used to have a cell phone holder but that is actually a universal GPS mount, it came with a backplate that was just flat so I didn't even have to do anything to it really, I got it at Target because it was on clearance. As far as leaving it there, I don't have any gauges and like to use it for a boost gauge, but it's still just as easy to remove as before for when I go to any shady areas.
  • 6 years later...
Posted
Okay have the limited 05 Legacy gt 5 speed, changed my rear shock and now she just cranks and cranks, got fuel and compression, no spark. Did I have car to high to trigger a kill or safety switch?? & anyone know location of it or it have to do with computer??? Please help shes been sitting for months over this issue.
