iNVAR Posted January 14, 2011 Share Posted January 14, 2011 Which drivers are you guys using? I think this is the last one I installed under Win7 64bit and everything works beautifully. http://www.crimetank.com/misc/CDM20602.zip Link to comment Share on other sites More sharing options...
AndrewZ Posted October 20, 2011 Share Posted October 20, 2011 Which drivers are you guys using? I think this is the last one I installed under Win7 64bit and everything works beautifully. www.crimetank.com/misc/CDM20602.zip Thanks for the link! I see in the folder for the drivers though that there's i386 and AMD64. Is i386 just for intel 32 bit or 64 also? Or would the AMD drivers work? I have a 64-bit Intel CPU. EDIT: I read elsewhere that the AMD64 drivers are the one to use in general for 64-bit Link to comment Share on other sites More sharing options...
NSFW Posted October 21, 2011 Share Posted October 21, 2011 i386 = 32-bit AMD64 = 64-bit, including most Intel 64-bit systems. Intel does (did?) make 64-bit systems that aren't AMD64-compatible, but I don't think you'll see those in anything but servers. I'm using an OpenPort 1.3 cable with Windows 7, but my OS is 32-bit. I'm pretty sure that the VAGCOM cable is equivalent to an OpenPort 1.3. Link to comment Share on other sites More sharing options...
planelazy Posted October 22, 2011 Share Posted October 22, 2011 I talked to some people at work today and they think it may be from having the 64bit operating system. Keith, which Windows 7 are you running? I am running the 64bit Professional. Is anybody else using Windows 64bit? I'm running 7 x64.. and VAG-COM from m sprank with no problems. It could be a driver issue. Link to comment Share on other sites More sharing options...
AndrewZ Posted October 23, 2011 Share Posted October 23, 2011 Just reporting back - I haven't tried EcuFlash but LearningView worked with the drivers iNVAR posted on my Windows 7 Pro 64 bit install Link to comment Share on other sites More sharing options...
G5892 Posted October 23, 2011 Share Posted October 23, 2011 I don't know why, but ecu flash wouldn't work when i used the Vag-Com cable. When I purchased the Openport 2.0, it worked flawlessly. I remember hearing that they designed the new ECU flash to not work with vag-com cables. There was a file that you could download to make it work, but the program doesn't work properly with windows 7. Hope this helps. Link to comment Share on other sites More sharing options...
