kmshark Posted July 1, 2010 Share Posted July 1, 2010 I have had a bad flywheel noise ever since I tried a simple change to a better clutch and flywheel - and now months later the transmission is making noise AND I have the common oil-burning issue. I'll go two weeks with no loss, then in one week I can loose over a quart. Does anyone know of a auto place in South Florida with experience that I can take me 05 LGT Wagon to? I've had it at two places that simply wasted my time/money with no idea/plan to address the oil issue and no knowledge about the clutch/flywheel/transmission. HELP!!! Link to comment Share on other sites More sharing options...
Max Capacity Posted July 2, 2010 Share Posted July 2, 2010 Have you looked in the vendor forum here or on nasioc or done a web search for subaru tuners or shops in FL. You may want to call the guy's at Titan Motorsports and see if they can recommend anybody. They are big drag racers and have a lot of different clients cars they work on. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
