Gemini91 Posted July 1, 2010 Share Posted July 1, 2010 Should there be a grille in the hood scoop? I'm new to LGT, so I really don't know... My car doesn't have one now... If I want to add one, where can I get it? Link to comment Share on other sites More sharing options...
RJS5689 Posted July 1, 2010 Share Posted July 1, 2010 They don't have one from the factory. You can make your own. Look in the cheap/free mod section on these forums. http://legacygt.com/forums/showthread.php/compilation-cheap-and-free-legacy-mods-84688.html Link to comment Share on other sites More sharing options...
Max Capacity Posted July 1, 2010 Share Posted July 1, 2010 It's easier just to take some small tools and unbend the bent fins. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ehsnils Posted July 1, 2010 Share Posted July 1, 2010 If you live in gravel road country you may want it - if not it's up to you. Make it yourself if you think you need it or it looks cool. Just be aware that it may limit the air flow for the IC a bit. Link to comment Share on other sites More sharing options...
LegacyGTBiggie Posted July 1, 2010 Share Posted July 1, 2010 ive always wondered about putting a aero honey comb thing over the IC... straighten out the airflow some... http://www-htgl.stanford.edu/bradshaw/tunnel/honeycomb.html Link to comment Share on other sites More sharing options...
teK-- Posted July 3, 2010 Share Posted July 3, 2010 The scoops in the Legacies aren't that big. I wouldn't think lack of mesh would be a problem unless you have a huge problem with bugs in your area. Link to comment Share on other sites More sharing options...
