Strizzy Posted July 11, 2010 Share Posted July 11, 2010 I have an '08 Spec.B stock and using the Cobb AP for Stage 1. Warranty expiring and want to do next step. Was thinking of the Cobb Downpipe and have a few questions for the resident experts: - Will the Cobb SS 3" DP give a decent performance improvement? - Will it mate with the stock exhaust? - Is it better to replace the exhaust as well at the same time as the DP? - Any benefits from keeping the stock downpipe and just putting on a new exhaust (e.g., Subie's SPT exhaust)? Tks a ton!!!! What part of IL are you from? I have a catted Invidia downpipe that I'm looking to get rid of in favor of a catless DP, once I figure out my engine issues. You can realistically use any downpipe you choose, as long as you get a 3" flange to bolt any aftermarket DP to the OEM exhaust. Any DP will give you about the same amount of gains, and it's quite a bit over stock. No major benefits to just replacing the CBE other than sound, especially if you go with a 3" DP and a stock sized CBE. My bad luck build Link to comment Share on other sites More sharing options...
peteyjr Posted July 12, 2010 Share Posted July 12, 2010 Although the difference is small, there are gains in choosing the right DP. I changed from a COBB Catted to an Invidia catted and felt a small difference. Bac5.2- Your ride should not be giving you major hesitation even in the heat wave we have been thru (less power yes). My stock Cobb tune pulled timing considerably in the heat but was greatly improved when Infamous massaged the tune. Link to comment Share on other sites More sharing options...
scoobydoobie Posted July 12, 2010 Share Posted July 12, 2010 I have an '08 Spec.B stock and using the Cobb AP for Stage 1. Warranty expiring and want to do next step. Was thinking of the Cobb Downpipe and have a few questions for the resident experts: - Will the Cobb SS 3" DP give a decent performance improvement? - Will it mate with the stock exhaust? - Is it better to replace the exhaust as well at the same time as the DP? - Any benefits from keeping the stock downpipe and just putting on a new exhaust (e.g., Subie's SPT exhaust)? Tks a ton!!!! - Yes - Yes - Doesn't matter - Not really Link to comment Share on other sites More sharing options...
EPLegacyGT Posted July 12, 2010 Author Share Posted July 12, 2010 Update: After putting more miles on the car I find the throttle response is back. I think the ECU was only getting used to it. Power is now more usable and the shutter around 3000 is gone. Only problem that remains is the rough idle. Link to comment Share on other sites More sharing options...
lltomtomll Posted July 13, 2010 Share Posted July 13, 2010 i can def say it hasnt drastically improved but from what everyone is saying i guess we just have to give the car some time to adjust and calibrate. if there isnt any noticable difference... worst case scenario, we can always just sell it? get some actual engine mods... I say you just go stg 2 im sure the throttle response will be quick after that DO IT! Link to comment Share on other sites More sharing options...
EPLegacyGT Posted July 14, 2010 Author Share Posted July 14, 2010 Im a sucker for peer pressure. lol. I think this thread can be closed now. Link to comment Share on other sites More sharing options...
VIIIFe Posted July 14, 2010 Share Posted July 14, 2010 I'be been running stage 1 for a few weeks and am waiting for my downpipe to come in. I bumped up my idle RPMs by 50 as suggested in other threads and that seemed to help the rough idle, FWIW. Link to comment Share on other sites More sharing options...
