armax1980 Posted June 27, 2010 Share Posted June 27, 2010 stock tire are 205/50R17 but the tire size tire rack recommends for the aftermarket 17x7 inch wheels are 215/45R17 . How big of a difference are they? Link to comment Share on other sites More sharing options...
Leke Posted June 27, 2010 Share Posted June 27, 2010 http://www.miata.net/garage/tirecalc.html Link to comment Share on other sites More sharing options...
armax1980 Posted June 28, 2010 Author Share Posted June 28, 2010 not much of a difference but has anyone here run aftermarket 17 inch wheels with the 215/45R17 and have any problems? Link to comment Share on other sites More sharing options...
stanjk3 Posted June 28, 2010 Share Posted June 28, 2010 not much of a difference but has anyone here run aftermarket 17 inch wheels with the 215/45R17 and have any problems? That's the stock size for the 05-09 GT (except Spec B). You can also go up a width to 225/45 17 and still be fine. If you're getting snow tires, you might want to stick with 205/50 17. Friends don't let friends drink cheap beer. Link to comment Share on other sites More sharing options...
Canon20D Posted June 29, 2010 Share Posted June 29, 2010 I kind of assumed this, but is there any problem with 215/40/17 instead of the 215/45/17? I am coming off of 205/50/17, and wanted a slimmer profile Link to comment Share on other sites More sharing options...
clarkwgriswold Posted June 29, 2010 Share Posted June 29, 2010 I would recomend 225/45/17. A little wider but still low profile. Don't go too low or it will ride like doo doo! Link to comment Share on other sites More sharing options...
krzyss Posted June 29, 2010 Share Posted June 29, 2010 I kind of assumed this, but is there any problem with 215/40/17 instead of the 215/45/17? I am coming off of 205/50/17, and wanted a slimmer profile Check load index. You do not want tires that cannot handle the weight of the car. Krzys Link to comment Share on other sites More sharing options...
Malt Beverage Posted June 30, 2010 Share Posted June 30, 2010 http://3.bp.blogspot.com/_pyKPRmw6O0E/TCthvTw0SXI/AAAAAAAAADc/Jz5whA99HTY/s640/225vs205.jpg I snapped this a while back. Its a good representation of the smallest and largest tires that are typically used on stock wheels for the Legacy. Not a big difference. though its 16" the one on the right is the same width as your OE tire. Link to comment Share on other sites More sharing options...
