07legacyGTturbo Posted June 26, 2010 Share Posted June 26, 2010 I just bought an 07 legacy GT 2.5 turbo with the SI-DRIVE. It runs awesome, I'm just wondering how it works and what does it control? Just the transmission? I'm just wondering... Thanks Link to comment Share on other sites More sharing options...
Squiden Posted June 26, 2010 Share Posted June 26, 2010 SI-Drive just controls the throttle mapping on the car. In "I" mode, if you floor the gas, you'll only get 70% throttle at the engine. In "S" mode, it drives like a normal car. and in "S#", you'll get WOT without needing to floor the gas peddle. Since it's just a throttle mapping, many will call it a gimmick - with a little right-foot modulation, you can get the same effect. Link to comment Share on other sites More sharing options...
07legacyGTturbo Posted June 26, 2010 Author Share Posted June 26, 2010 Ok thanks! Link to comment Share on other sites More sharing options...
SasquachGT Posted June 26, 2010 Share Posted June 26, 2010 If you are an aggressive driver, like me, you'll always want it on S#. Not just for more acceleration but for throttle response. Link to comment Share on other sites More sharing options...
RJS5689 Posted June 26, 2010 Share Posted June 26, 2010 SI-Drive just controls the throttle mapping on the car. In "I" mode, if you floor the gas, you'll only get 70% throttle at the engine. In "S" mode, it drives like a normal car. and in "S#", you'll get WOT without needing to floor the gas peddle. Since it's just a throttle mapping, many will call it a gimmick - with a little right-foot modulation, you can get the same effect. Right idea, but the numbers are slightly off. In "I" mode you have a maximum of about 40% of engine power I believe it is. Throttle inputs are delayed and it cuts off at something like 40 or 50% throttle. So at WOT the throttle is only open 40-50%. In "S" mode the car drives like normal. For every 1 degree you open the throttle you get 1% of power. With the pedal pushed half way, you have 50% of the throttle being opened. In "S#" mode the response is doubled. For every degree you press the pedal, you get 2% of the throttle opened. This effectively means you are at full throttle even if you only have the gas pedal pressed half way. I used to use "S#" when the car was stock and stage 1, but now that I'm at stage 2 "S#" has just become way too aggressive and jerky. Link to comment Share on other sites More sharing options...
LegacyMUN2k6 Posted June 26, 2010 Share Posted June 26, 2010 I use "I" mode 99.9% of the time to conserve fuel. Link to comment Share on other sites More sharing options...
Darkness of Death Posted June 26, 2010 Share Posted June 26, 2010 one time i went to the dealership and the service advisor was talking to me about the "knob". he thought it was to control the suspension settings Link to comment Share on other sites More sharing options...
dmanaenk Posted June 26, 2010 Share Posted June 26, 2010 Sigh, laziness meets post-whoring. OP, this has been discussed like a gazillion times, use a search. 666 Link to comment Share on other sites More sharing options...
boymk123 Posted June 26, 2010 Share Posted June 26, 2010 If you are an aggressive driver, like me, you'll always want it on S#. Not just for more acceleration but for throttle response. also remember the "blue dot" won't let you do S# Link to comment Share on other sites More sharing options...
SSlick406 Posted June 26, 2010 Share Posted June 26, 2010 "I" mode is meh! How much fuel is actually conserved? Not worth the lack of driving experience IMO. Link to comment Share on other sites More sharing options...
SlickSpur Posted June 27, 2010 Share Posted June 27, 2010 I use "I" mode 99.9% of the time to conserve fuel. Ditto Link to comment Share on other sites More sharing options...
boymk123 Posted June 27, 2010 Share Posted June 27, 2010 I use "I" mode 99.9% of the time to conserve fuel. in Boston traffic, yes, same here, 99.9999% "I" mode Link to comment Share on other sites More sharing options...
musty_hustla Posted June 27, 2010 Share Posted June 27, 2010 I wish the 2k10s had SI-drive, seems like a fun feature. Link to comment Share on other sites More sharing options...
SlickSpur Posted June 28, 2010 Share Posted June 28, 2010 Is there any reason you shouldn't switch SI modes while under throttle? I, out of habit, put my car into neutral before I switch modes, but don't really know if thats necessary... Link to comment Share on other sites More sharing options...
