optyks Posted June 25, 2010 Share Posted June 25, 2010 Anyone either know how to replace brake pads or know a place with decent prices who would install pads for a reasonable price? If someone helps I'd obviously pay compensation. Link to comment Share on other sites More sharing options...
McDowell Performance Tunin Posted June 25, 2010 Share Posted June 25, 2010 If your car is like mine, you'll probably need to have your rotors either resurfaced, or replaced. Just the pads is a fairly easy job. how are your rotors looking? www.facebook.com/mcdowelltuning [sIGPIC][/sIGPIC] Click Here for Stage1, Stage2 and Stage3 Tuning and eTuning Info Link to comment Share on other sites More sharing options...
tnwlf13 Posted June 25, 2010 Share Posted June 25, 2010 ^+1 Had to resurface my rotors as well, as long as they are within specs you can get them done at most auto parts stores pretty cheap. Swapping pads is easy, but bleeding the lines is an awful lot easier if you have a buddy. Link to comment Share on other sites More sharing options...
McDowell Performance Tunin Posted June 25, 2010 Share Posted June 25, 2010 I've got a pump you can borrow, that can be used for bleeding your brakes. But as mentioned, you'll be better off going with some aftermarket rotors, if you can afford them. BTW, how are both of your tunes feeling? They're going to feel weak in the summer, because of the heat; mine is...damn heatsoak. www.facebook.com/mcdowelltuning [sIGPIC][/sIGPIC] Click Here for Stage1, Stage2 and Stage3 Tuning and eTuning Info Link to comment Share on other sites More sharing options...
tnwlf13 Posted June 26, 2010 Share Posted June 26, 2010 I love it, but it has me wanting more. Swaybars are next though, and I still need to dig out that old laptop and do some logs to send to you and have you check and make sure everything still looks good. Link to comment Share on other sites More sharing options...
McDowell Performance Tunin Posted June 26, 2010 Share Posted June 26, 2010 yeah, that's the only problem with modding...there's always more that can be done. www.facebook.com/mcdowelltuning [sIGPIC][/sIGPIC] Click Here for Stage1, Stage2 and Stage3 Tuning and eTuning Info Link to comment Share on other sites More sharing options...
keithk831 Posted June 26, 2010 Share Posted June 26, 2010 yeah, that's the only problem with modding...there's always more that can be done. x2. That's why I have Perrin mufflers on the way Link to comment Share on other sites More sharing options...
optyks Posted June 26, 2010 Author Share Posted June 26, 2010 THanks for the prompt replies. As for resurfacing, how can I tell when I'd need to? Money is becoming a bit tight so if it's not really necessary I won't do it. As for replacing anything, I don't have any experience in this field so I'd definitely need some help. Tune still feels great. Thanks! Does seem a bit slow with this warm air and all, but thats alright. Still easy to pass people Link to comment Share on other sites More sharing options...
tnwlf13 Posted June 26, 2010 Share Posted June 26, 2010 If you've never had them resurfaced, then you probably need to. Visually, the entire surface of the rotor should be smooth all the way out to the edge. Mine had quite a bit of buildup on the outside edges. Resurfacing is not expensive at all, cost me 30 bucks for the two and it only takes them about an hour. Replacing rotors (assuming the old ones are still within spec) is not necessary on a stage 1 daily driver. Logan's pump will help a ton, but you're right to want help from someone experienced, brakes are sorta important and all. Link to comment Share on other sites More sharing options...
holyjoetart Posted June 26, 2010 Share Posted June 26, 2010 I haven't checked the prices lately, but it might be cheaper for a mechanic to purchase blanks from napa or checker than to resurface old ones. Might want to look into it. Link to comment Share on other sites More sharing options...
optyks Posted June 27, 2010 Author Share Posted June 27, 2010 Also, would there be any problem in having fronts done at one time and having rears done later, maybe a month or two separate? Link to comment Share on other sites More sharing options...
McDowell Performance Tunin Posted June 27, 2010 Share Posted June 27, 2010 Yeah, I would replace the pair with the least amount of life left first. You can do the other set later. www.facebook.com/mcdowelltuning [sIGPIC][/sIGPIC] Click Here for Stage1, Stage2 and Stage3 Tuning and eTuning Info Link to comment Share on other sites More sharing options...
