iamthelazerviking Posted June 20, 2010 Share Posted June 20, 2010 Does anyone know where the TPS on a 92 Legacy is located? If you know other years, like 90-95 it should be the same. Thanks Link to comment Share on other sites More sharing options...
Platinum_Racing Posted June 20, 2010 Share Posted June 20, 2010 If you remove the plastic engine cover it's located on the throttle body. Find the throttle cam that has the spring on it and a cable leading to it, then look to the left on the other side of the throttle body. It is a black plastic sensor with wires coming out of it. http://i338.photobucket.com/albums/n415/Wargrimes88/EJ22aSmall.jpg Link to comment Share on other sites More sharing options...
iamthelazerviking Posted June 21, 2010 Author Share Posted June 21, 2010 Got it thaaaaaanks Link to comment Share on other sites More sharing options...
