westy66 Posted June 19, 2010 Share Posted June 19, 2010 it is even worth swapping to a larger turbo, albeit a small one, if youre not going to be updating the fuel system? Link to comment Share on other sites More sharing options...
TiredGXP Posted June 20, 2010 Share Posted June 20, 2010 So, why are you looking to upgrade the turbo? Are you looking for more airflow? If so, then you need to enough fuel to use that extra airmass. *Maybe* your existing pump/regulator/injectors can do this, maybe not. Do you know what your existing IDC is? How much more airflow are you expecting? If your existing fuel system can't handle the larger turbo, there's no point in upgrading the turbo - you'd have to dial back the boost to match your fuel system capability anyway. To do otherwise will probably result in a broken engine. :cheers: Link to comment Share on other sites More sharing options...
John M Posted June 20, 2010 Share Posted June 20, 2010 I'd say the 16g is fine on stock fuel. You can take advantage of all that low end power where you've got extra injector capacity anyway and taper it up top if you're getting close to max duty cycle. Link to comment Share on other sites More sharing options...
