Zac88 Posted June 18, 2010 Share Posted June 18, 2010 Theres a weird knocking or popping like noise coming from the front drivers side of my engine on a 2005 LGT wagon. Thats cylinder #2 i'm guessing? It only happens when the engine is under load. It idles fine. if I rev it up slowly it does not make the noise only if I floor it or accelerate quickly. I can post up a video if you guys like, it almost sounds like air escaping? Definetly does not sound like piston slap or a spun bearing. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 18, 2010 Share Posted June 18, 2010 Check for bubbles in your overflow tank, could it be a HG going ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
hifonic Posted June 19, 2010 Share Posted June 19, 2010 Any power loss?notice any smoke etheir? Link to comment Share on other sites More sharing options...
ehsnils Posted June 20, 2010 Share Posted June 20, 2010 Check the header and gaskets around the header too. Also check the oil so it doesn't contain water. Link to comment Share on other sites More sharing options...
Zac88 Posted June 20, 2010 Author Share Posted June 20, 2010 Just did an oil change couple days ago but the sound is still there. I'll get under the car tomorow and check for exhaust leaks. Link to comment Share on other sites More sharing options...
Zac88 Posted June 20, 2010 Author Share Posted June 20, 2010 I've used Castrol Edge 5w-30 since i've owned the car. Link to comment Share on other sites More sharing options...
ehsnils Posted June 21, 2010 Share Posted June 21, 2010 I was more thinking of water in the oil as an indication of a failed headgasket. Link to comment Share on other sites More sharing options...
OhBe1 Posted June 21, 2010 Share Posted June 21, 2010 So the sounds was there before the oil change? How long has the noise been there? how many miles on the car? 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
Zac88 Posted June 21, 2010 Author Share Posted June 21, 2010 Sound has only been there for 2 weeks now. Sound was there before this last oil change. I have done 3 oil changes on the car now, I have owned it since april with 108,000km on it. 122,000km on the car so about 60,000 miles? Link to comment Share on other sites More sharing options...
Zac88 Posted August 14, 2010 Author Share Posted August 14, 2010 car is still making the noise after I changed the exhaust gaskets. Can anyone please help? Link to comment Share on other sites More sharing options...
Telephonewire Posted February 12, 2012 Share Posted February 12, 2012 Hi, Did you every get to the bottom of your noise? "It only happens when the engine is under load. It idles fine. if I rev it up slowly it does not make the noise only if I floor it or accelerate quickly." Regards, Telephonewire Link to comment Share on other sites More sharing options...
