Johnish Posted June 15, 2010 Share Posted June 15, 2010 P215/45ZR-18 BFGoodrich g-Force T/A KDWS I have had 6 of these tires, which I'll explain shortly, and 3 of them have failed with BUBBLE BULGE of the sidewall. I purchased a set (4) of them and 3 of these original 4's have had a bubble bulge in the sidewall. I had to purchase a set of 2 only 8 months after my original purchase because both of the 2 had the bulge. Now that the 3rd one has gone I'm and going to switch tires. I just wanted to post because I've written BFGoodrich about the problem when the 2 were damaged and received a response that this problem was isolated and probably caused by improper driving surface and not an issue with the tires. HMPH! So anyone else having this problem? Thanks, John Link to comment Share on other sites More sharing options...
krzyss Posted June 15, 2010 Share Posted June 15, 2010 Most cases of sidewall buble are caused by "driving surface". Hard to tell if your case is typical. Krzys Link to comment Share on other sites More sharing options...
CwhillVT Posted June 15, 2010 Share Posted June 15, 2010 I have a set and am almost to the wear bars. I have had no problems other than having to repalce one that I tore up on the track (my fault-the rough track took chunks out of the shoulder on the front driverside). I have to say that other than a little extra road noise, these have been great tires. Sorry to hear about your troubles. Link to comment Share on other sites More sharing options...
devobuzz Posted June 15, 2010 Share Posted June 15, 2010 I had sidewall bubble caused by improper mounting... Link to comment Share on other sites More sharing options...
