Jeffzguy Posted June 10, 2010 Share Posted June 10, 2010 Sometimes when my car sits for a day or so there is a delay from keyturn to engine start. I turn the key and it waits 3-5 seconds before anything happens. Most of the time it just starts real fast but I worry it may not start at some point. Do you think it is a solenoid going out? Link to comment Share on other sites More sharing options...
Bdubs Posted June 10, 2010 Share Posted June 10, 2010 Possibly the starter solenoid contacts. Only a few bucks, and pretty easy to replace. Link to comment Share on other sites More sharing options...
sqc151 Posted June 10, 2010 Share Posted June 10, 2010 check ur battery connections too, the negative can be a pita sometimes. Link to comment Share on other sites More sharing options...
fkyx Posted June 11, 2010 Share Posted June 11, 2010 Is the delay between key-turn and cranking? If that's the case and the other things people mentioned check out, you may want to check your ignition switch. Link to comment Share on other sites More sharing options...
Platinum_Racing Posted June 11, 2010 Share Posted June 11, 2010 +1 for the solenoid contacts and the negative lead. Rusty grounds and corroded terminals can cause all sorts of strange things. Link to comment Share on other sites More sharing options...
