WESTcoast Posted June 2, 2010 Share Posted June 2, 2010 So I am coming to the conclusion of my suspension setup, all i have are some different springs to put on. Usually when you go through suspension work you get noise and you get somewhat uncomfortable ride. althogh this is my first suspension setup, i have friends with similar setups and their car has a ride in which you wouldn't want to go for a long cruise in, yet mine feels completely stock! Here are the mods: -whiteline front 20mm sway bar -03 WRX GR-2 struts with Ebachi Pro Kit lowering springs -Whiteline endlinks -CUSCO 24 adjustable sway bar -Whiteline adjustable rear endlinks -Rear subframe lock-down bolts -Rear diff mount with Turn in Concepts hardened bushings -STi aluminum rear lateral links with Group N bushings I can cruise on a bumpy street and it will feel like im in my outback smooth and comfortable. When Im drivng the backroads, its like im on a roller coaster(minus me sliding around in leather seats). I am just really happy with my setup and dont have any plans on changing it other than replacing bushings that I know are going out and trying out these set of S-tech (ewwww i know i know) that i have laying around. Does anyone else have a smooth setup that they like? Link to comment Share on other sites More sharing options...
Zues Marine Posted June 3, 2010 Share Posted June 3, 2010 not smooth per se, but damn is this thing a slot car! KYB GR-2 struts H&R sport springs 215/45/17 potenza's 22mm Rear Sway 25mm Front sway steering rack bushings STI rear endlinks being used on my front whiteline rear endlinks rallitek swaybar bushings front strut tower bar, rear strut tower bar etc. i cant remember what else, its more grip>smoothness but i kinda like the bumpy ride Link to comment Share on other sites More sharing options...
WESTcoast Posted June 3, 2010 Author Share Posted June 3, 2010 sounds like a good setup how do you like the 25mm front sway im guesisng its from a tribeca? here is a pic of my undercarrige http://i63.photobucket.com/albums/h125/djkool707/30844_1125856884232_1761470157_2258.jpg Link to comment Share on other sites More sharing options...
bmwpride Posted June 3, 2010 Share Posted June 3, 2010 where did you get that rear diffuser Link to comment Share on other sites More sharing options...
jantzen8895 Posted June 3, 2010 Share Posted June 3, 2010 From a tribeca? that's what i need how much did you snag that for? Link to comment Share on other sites More sharing options...
WESTcoast Posted June 3, 2010 Author Share Posted June 3, 2010 where did you get that rear diffuser Its from an 05 STi if you want it you can have it, the address of the part is somewhere on HWY 680 between Concord and San Jose last week easy come easy go! Link to comment Share on other sites More sharing options...
WESTcoast Posted June 3, 2010 Author Share Posted June 3, 2010 From a tribeca? that's what i need how much did you snag that for? I seen a couple at a pick and pull once, you can get them for 30-50 bucks Link to comment Share on other sites More sharing options...
Zues Marine Posted June 3, 2010 Share Posted June 3, 2010 or new from the dealer for like $60.. need to do some modification to get it to fit tho Link to comment Share on other sites More sharing options...
