BAC5.2 Posted June 19, 2010 Share Posted June 19, 2010 What kind of NVH increase have you guys noticed? The car does NOT Like sharp changes in pavement, even with the stock suspension. So driveways that are slightly raised over the road surface, sounds terrible unless you creep up them. Figured LCA's might help. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Max Capacity Posted June 19, 2010 Share Posted June 19, 2010 What kind of NVH increase have you guys noticed? The car does NOT Like sharp changes in pavement, even with the stock suspension. So driveways that are slightly raised over the road surface, sounds terrible unless you creep up them. Figured LCA's might help. Most of us call that better road feel. If your getting a knock going into the driveway, 9 out 10 times it's end links. Get those cheap OEM's out of there and putting some solid ones in. I went with Perrin's. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jmun671 Posted June 19, 2010 Share Posted June 19, 2010 Although I'm a 3G WRX owner I'd like to add to this since our suspensions are very similar. I've had the Whiteline version installed and have used them for over 4k miles. The passenger side bushing started to separate from the press sleeve; I noticed this after making a recent U-turn and heard/felt a loud thump from the front suspension. I rarely drove my car over the past year. I recalled that Whiteline has a 1-yr warranty on parts so I emailed them pics & details of my situation. I was about 1-week over due and they still sent me a replacement kit without hassle! Because of this customer service alone I will continue to patronize Whiteline. Very satisfied with their service (FYI I deal with Whiteline AUS directly because of my location). Service aside, the bushings are great and they improve road feel. NVH increase is minimal and I got 2.7 degrees +caster out of them which helped me in autox. Before the turn-in was very delayed and spongy. There is a definite decrease in brake dive & squat that I noticed. Dramatic improvement now with the LCA installed. As a side note the new kit looks revised and will be installing them soon. Hope this helps. J Link to comment Share on other sites More sharing options...
ninjakc Posted June 24, 2010 Share Posted June 24, 2010 The local Sub dealer wants 440 to replace my bushings. Not sure if its both front and rear, they just recommended "bushings". But since the OEM are 9 bucks at FredBean my bushings and I are both getting ripped. Link to comment Share on other sites More sharing options...
AZP Installs Posted June 24, 2010 Share Posted June 24, 2010 Well don't forget there is a book time to replace the LCA Bushings, and that's probably how the dealer is getting the cost up there. We charge about $200 for the labor to do the bushings and it takes about 2.5-3hrs to do it. Where are you located? If it's the NY/NJ area, hit us up. -mike Link to comment Share on other sites More sharing options...
BAC5.2 Posted June 28, 2010 Share Posted June 28, 2010 Service aside, the bushings are great and they improve road feel. NVH increase is minimal and I got 2.7 degrees +caster out of them which helped me in autox. Before the turn-in was very delayed and spongy. There is a definite decrease in brake dive & squat that I noticed. Dramatic improvement now with the LCA installed. As a side note the new kit looks revised and will be installing them soon. Hope this helps. J 2.7 degrees TOTAL? That doesn't seem like a lot. I was running 7.4/7.9 degrees with my coilovers. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
GTTuner Posted June 28, 2010 Share Posted June 28, 2010 And you adjusted caster to?????????????????????????????? To what ever makes ME happy? . I actually do not have offset LCA's at this time. I am running some experimental bushings right now. Link to comment Share on other sites More sharing options...
jmun671 Posted June 29, 2010 Share Posted June 29, 2010 2.7 degrees TOTAL? That doesn't seem like a lot. I was running 7.4/7.9 degrees with my coilovers. Thanks for pointing that out I meant to type 6.7 degrees total caster. Fat fingered that number I guess. I'll take any caster I can get! J Link to comment Share on other sites More sharing options...
homegrwn97 Posted August 13, 2013 Share Posted August 13, 2013 BUMP! So an Anti Lift Kit for our LGT's are known as the LCA bushings...correct? Im planning to do some suspension upgrades without lowering the car. I want to stay stock...but have better handling with my Wagon. Link to comment Share on other sites More sharing options...
ttnio Posted August 14, 2013 Share Posted August 14, 2013 The kind of tires you will be using,will also be a factor. Lots of things to consider in an upgrade. Good luck,have fun. Link to comment Share on other sites More sharing options...
AZP Installs Posted August 14, 2013 Share Posted August 14, 2013 BUMP! So an Anti Lift Kit for our LGT's are known as the LCA bushings...correct? Im planning to do some suspension upgrades without lowering the car. I want to stay stock...but have better handling with my Wagon. Technically they are Front Lower Control Arm REAR Bushings. You will want to replace both the Front Lower Control Arm REAR Bushings and the INNER bushings. Currently the Whiteline adjustable caster LCA Rear bushings are great but out of stock. The alternative is the AVO modified (non-adjustable) Rear bushings. For the inners you want the WL inner LCA Bushings. We sell either package (Rear + Inner) for $180 shipped. -Mike Paisan http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/145749898/original.jpg http://www.pbase.com/paisan/image/133406601.jpg http://www.whiteline.com.au/images/logos/perf1.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
alessandro132 Posted September 4, 2013 Share Posted September 4, 2013 J Speed make a solid silicon caster-adjustable rear LCA bush which is made in Japan and very popular with the Liberty guys in Australia (and am running this in my car). Benefits are that it is solid construction so requires no lubricating and comes with three different-sized shims to vary caster adjustment. Not the cheapest out there ($240 AUD) but another alternative. http://i86.photobucket.com/albums/k97/faatgt/jbushes.jpg Link to comment Share on other sites More sharing options...
ras06LGT Posted September 4, 2013 Share Posted September 4, 2013 Just installed the AVO offset rear bushings and Whiteline front inner bushings this past weekend. I was going to go with the Whiteline ALK, but as Mike said, they are out of stock right now and I didn't want to wait a month. I'm very happy with how the car drives now. The front end tightened up considerably, and the extra caster is really nice. Less steering correction needed, and better straight-line holding. I don't see much benefit from the adjustable caster options, as I would most likely run them at max setting anyways. I did notice an increase in NVH, especially over expansion strips on the freeway. I don't find it objectionable at all, and the benefits of the better bushings far outweight the drawbacks. I'm already used to them, and don't really notice anymore. I think my total install time was ~5 hours, from car up to car down, and driving to a buddy's house to use his press. Link to comment Share on other sites More sharing options...
mikeyvt Posted September 28, 2013 Share Posted September 28, 2013 Technically they are Front Lower Control Arm REAR Bushings. You will want to replace both the Front Lower Control Arm REAR Bushings and the INNER bushings. Currently the Whiteline adjustable caster LCA Rear bushings are great but out of stock. The alternative is the AVO modified (non-adjustable) Rear bushings. For the inners you want the WL inner LCA Bushings. We sell either package (Rear + Inner) for $180 shipped. -Mike Paisan Do you have both in stock? Link to comment Share on other sites More sharing options...
AZP Installs Posted September 28, 2013 Share Posted September 28, 2013 We have the WL Front Inner Bushings and the AVO Lower Rear Bushings w/Caster Adjustment. $180 Shipped for the Combo. I verified they are in stock. -Mike Paisan http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/145749898/original.jpg http://www.pbase.com/paisan/image/133406601.jpg http://www.whiteline.com.au/images/logos/perf1.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Now we have an Online Catalog where you can purchase Parts! AZPParts.com Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
lingling1337 Posted September 28, 2013 Share Posted September 28, 2013 Those J Speed look really nice. I had Group N before and now I'm on the WALK, set to full caster. Steering is nice but I just hope they hold up. Link to comment Share on other sites More sharing options...
JamiSteven Posted June 13, 2014 Share Posted June 13, 2014 Sorry to bump this from the dead but can anyone chime in as to the longevity of their choice in LCA bushings? Ive read horror stories on nearly all of them, whiteline's splitting after 2k, Superpro's after 1k, AVO as well... Ide like to only do this once if possible :-) Link to comment Share on other sites More sharing options...
AZP Installs Posted June 16, 2014 Share Posted June 16, 2014 Sorry to bump this from the dead but can anyone chime in as to the longevity of their choice in LCA bushings? Ive read horror stories on nearly all of them, whiteline's splitting after 2k, Superpro's after 1k, AVO as well... Ide like to only do this once if possible :-) We've seen some Whiteline issues but most of those were on the earlier units. The AVOs I haven't seen any issues with the AVOs on the LGTs so far. -Mike Paisan http://www.pbase.com/paisan/image/153798190.jpg Maintaining, Modifying and Educating TriState Enthusiasts since 2001. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
