max751 Posted June 14, 2004 Share Posted June 14, 2004 I've been "observing" here a while, but decided to come out of hiding for a bit. When I read the specs, I see the trunk at 11.4 cu ft. That's pretty small, but when I look at the trunk, it looks a lot bigger than that. So I did some rough measurements. Unfortunately I didn't realize until later that my measurements do add up to a lot more than 11.4 cu ft and don't have an easy way to redo them for a while. I got 40" from front to back of the trunk. I know the front slopes, so this is somewhat generous. I got 43" between the wheel wells, and 17" from floor to the heavy steel wires at the top. Now I believe there are a few things near the front of the trunk which might hang a bit below the heavy wires plus the front slope which would reduce volume. On the other hand, there are some spaces in front of and behind the wheel wells which I did not include. Anyway when I multiply that out, I get well over 16 cu ft. I wondered if someone who has easy access to a Legacy sedan could do some measurements and see what they get as the real volume of that trunk. Thanks. Link to comment Share on other sites More sharing options...
7stars Posted June 14, 2004 Share Posted June 14, 2004 I agree. The trunk looks very big. It's very efficient compared to my Solara, which has huge wheel wells for the struts, and towards the rear seats it's very narrow. I always find it a tough time fitting things in there, especially with the high bumper. Fortunately we don't have rear struts and the bumper is not too high. Link to comment Share on other sites More sharing options...
Th3Franz Posted June 14, 2004 Share Posted June 14, 2004 Ah, double thread. Mods eliminate one of them. I hope the trunk is big enough for a decently sized enclosure. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
Drift Monkey Posted June 15, 2004 Share Posted June 15, 2004 When I looked inside, it looked like plenty of room Franz. An good-sized enclosure shouldn't be too much of a problem. Link to comment Share on other sites More sharing options...
