phenryiv1 Posted May 17, 2010 Share Posted May 17, 2010 http://legacygt.com/forums/showthread.php/video-autox-05-15-10-summit-point-washington-circuit-137778.html?p=2952310 3 videos in the link. Car did okay, but the course was set up for high-HP cars. In the past, AWD was a huge advantage on that course/track, but that was not the case this weekend. I had no power to accellerate rapidly out of the turns. Being able to lay on the power where the course straightened out would have helped a lot. Patrick Looking for spacers or adapters to install aftermarket speakers in the doors of your Legacy? CLICK HERE or PM me! http://www.carstereoadapters.com./ Link to comment Share on other sites More sharing options...
Jmhm17 Posted May 24, 2010 Share Posted May 24, 2010 do you have any suspension mods or are you bone stock? Link to comment Share on other sites More sharing options...
phenryiv1 Posted May 24, 2010 Author Share Posted May 24, 2010 do you have any suspension mods or are you bone stock?I "upgraded" to a Legacy GT RSB and installed stock LGT front struts with Tein H-Tech springs. Rear struts/springs are stock 2.5i parts. Tires are 215/45/17 BFG g-Force T/As on Rota SDRs. Stock calipers and pads. Patrick Looking for spacers or adapters to install aftermarket speakers in the doors of your Legacy? CLICK HERE or PM me! http://www.carstereoadapters.com./ Link to comment Share on other sites More sharing options...
burnout8488 Posted May 31, 2010 Share Posted May 31, 2010 GT RSB and Front Struts are generally accepted as being the same exact parts as 2.5i. Do you have a comparison pic of the rear sway bar? Maybe they are different but nobody's really proven it. Link to comment Share on other sites More sharing options...
phenryiv1 Posted June 1, 2010 Author Share Posted June 1, 2010 I disagree that they are considered to be the same: http://legacygt.com/forums/showthread.php/neededi-specb-rsb-2-5i-111744.html?t=111744 GT RSB and Front Struts are generally accepted as being the same exact parts as 2.5i. Do you have a comparison pic of the rear sway bar? Maybe they are different but nobody's really proven it. I measuered the diameters of the 2 bars, and the GT bar was 1mm thicker than the stock 2.5i RSB. As far as the struts, I doubt that there is a difference between 2.5i and GT struts (though they do have different part numbers, so maybe the valving is different). I only used the GT struts because I bought a complete front strut assembly (L&R) complete with bearings/tophats/etc. so that I could do a full swap-in/swap-out of my suspension. I left my 2.5i parts fully assembled and installed the Teins on the spare set, then plopped the full assembly into the car without needing to disassemble my stock parts. It makes it easier to go back to stock when I sell. Patrick Looking for spacers or adapters to install aftermarket speakers in the doors of your Legacy? CLICK HERE or PM me! http://www.carstereoadapters.com./ Link to comment Share on other sites More sharing options...
