BENCOB Posted May 8, 2010 Share Posted May 8, 2010 Time for our 75k mile maintenance and here is the recommendation and prices from 2 area dealer service shops This first one is for 200$ plus tax * Change Engine Oil, Filter & Crush Washer * Check and Top Off All Fluid Levels * Lube All Hinges & Latches * Check & Adjust Tire Inflation (Including Spare) * Rotate Tires * Replace Air Filter & Clean Filter Box * Inspect Transmission Fluid & Gear Oil * Inspect Steering, Axle & Suspension Parts * Inspect Drive Shaft Boots * Inspect Exhaust System * Inspect Clutch Adjustment * Inspect Battery Fluid Level & Test * Inspect Visually Supplemental Restraint System * Inspect Brake System * Inspect Drive Belt(s) * Scan for Open Recall(s) * Wash & Vacuum * Replace cabin filter Here is second package: 75K CONSISTS OF OIL CHANGE $29.95+TAX,CABIN AIR FILTER REPLACED $99.95+TAX,ENGINE AIR FILTER REPLACED $99.95+TAX,DIFFERENTIAL SERVICE FRONT AND REAR$139.90+TAX,TRANMISSION SERVICE$99.95+TAX,BRAKE FLUSH$99.95+TAX,FUEL SYSTEM SERVICE $39.95+TAX,TIRE ROTATION WITH BALANCE $49.95+TAX AND 49 POINT INSPECTION COST FOR PACKAGE IS $359.95+TAX Link to comment Share on other sites More sharing options...
