N.sane Posted May 3, 2010 Share Posted May 3, 2010 Here's the link for rear endlinks, it's only on the GT page for some reason, but it will fit our cars http://www.rallitek.com/rarehden.html This is the AVO rear sway bar mount. Stock mount is weak sauce for aftermarket bars, highly recommended if you get a rear sway. http://www.rallitek.com/avorestmore.html I would suggest springs+dampers before deciding if you need sways though. Most people will say sway bars are best bang for buck. It's true to an extent though. Yes, it will get rid of most of the body roll, but you may sacrifice overall grip for it, especially if you're running all-seasons. Link to comment Share on other sites More sharing options...
thestratomaster Posted May 3, 2010 Author Share Posted May 3, 2010 to keep things as cheap as possible, this is what i'm thinking at this point. -Get some springs and roll with those for a bit to see how the ride is improved and where it could still use improvement. -Get a short throw, because those are always fun. -And I'll try to find some good cheap/used mufflers/catback. That seems like a decent upgrade to hold me over for a bit till i see what else I want to do right? Link to comment Share on other sites More sharing options...
katalyst Posted May 4, 2010 Share Posted May 4, 2010 i'd prob forego the mufflers, and just combine that with money for springs to just get dampers right off the bat. there isn't really any gains to be had from aftermarket exhaust. could just get an avo panel intake and remove the resonator if you want a little more noise. short throw is a good idea though Link to comment Share on other sites More sharing options...
thestratomaster Posted May 4, 2010 Author Share Posted May 4, 2010 so get dampers instead of springs? or also get springs? Link to comment Share on other sites More sharing options...
N.sane Posted May 4, 2010 Share Posted May 4, 2010 If money is tight, I'd do dampers with stock springs. It would be better than stock dampers with aftermarket springs. Link to comment Share on other sites More sharing options...
thestratomaster Posted May 4, 2010 Author Share Posted May 4, 2010 The dampers would retain stock height, just improve handling etc? Link to comment Share on other sites More sharing options...
thestratomaster Posted May 4, 2010 Author Share Posted May 4, 2010 also, best dampers for the price? 1, 2, 3....go Link to comment Share on other sites More sharing options...
katalyst Posted May 4, 2010 Share Posted May 4, 2010 yeah stock height will be retained since you're using the stock springs konis are generally a recommended damper for the legacy. the front however is an insert and you'll need to do a bit of slicing with the stock housing. i have a link somewhere on my home computer but i'm at work right now. not sure if you're interested in doing that though. Link to comment Share on other sites More sharing options...
thestratomaster Posted May 4, 2010 Author Share Posted May 4, 2010 how much work would it be? I would probably have a shop install those anyways. I read somewhere about people removing the intake silencer. Not that that would give a performance increase, but it seems to give it more intake noise that would be nice. How do I do that? Link to comment Share on other sites More sharing options...
katalyst Posted May 5, 2010 Share Posted May 5, 2010 it's more a DIY job, here's the link http://forums.nasioc.com/forums/showthread.php?t=1219607 if you'd like a more plug and play setup, i'd prob give the tokico HTS dampers consideration, but you do need to get the spec B top hats for them to work, which is an extra $120 mach v motorsports / fast wrx sells them here, $621: http://www.fastwrx.com/tohtssh.html Link to comment Share on other sites More sharing options...
katalyst Posted May 6, 2010 Share Posted May 6, 2010 on second thought, you might just be better off getting a set of bc racing coilovers or the tein basic coilovers, both come in right around 1k and the install is easier and should cost you less shop time. Link to comment Share on other sites More sharing options...
AKLGT Posted May 7, 2010 Share Posted May 7, 2010 upgrade to better brake pads better tires Rear Sway Bar (minimum) Better springs (or coilovers) Tint or Clear Bra for the hood/front bumper Use anything else towards the balance of the car. Wiggle wiggle wiggle wiggle wiggle yeah!!! Link to comment Share on other sites More sharing options...
thestratomaster Posted May 9, 2010 Author Share Posted May 9, 2010 Im not sure I trust myself doing suspension work yet hah. Whatever I got would go to a shop. I would do sways, exhaust and short throw, but thats probably the most I could get away with in my garage. So for dampers konis, and springs rallitek. and bc's for coilovers. I have some thinking to do I guess Link to comment Share on other sites More sharing options...
cybonic Posted May 10, 2010 Share Posted May 10, 2010 best strut spring combo = b8 + eibach best for value coils = bc or jic get cusco f & r sways. still lacking? get cusco H brace for more precise turn-in Link to comment Share on other sites More sharing options...
cybonic Posted May 10, 2010 Share Posted May 10, 2010 remember to get the avo rsb mounting bracket. the stock 1s will crack. endlinks are optional. Link to comment Share on other sites More sharing options...
thestratomaster Posted May 10, 2010 Author Share Posted May 10, 2010 the b8's are just the spec b struts? Link to comment Share on other sites More sharing options...
thestratomaster Posted May 10, 2010 Author Share Posted May 10, 2010 also because struts are much more wallet heavy and Im on a budget, can I get away with springs on stock struts for long enough to get struts? Link to comment Share on other sites More sharing options...
N.sane Posted May 10, 2010 Share Posted May 10, 2010 I'm using Vogtland springs on stock struts. It's totally OK to use aftermarket springs on stock dampers, it's just not OMFG AWESOME lol. Just dont get anything that drops the car super low, like Tein S.tech. Get something with a mild drop like the Vogtland's I have, Eibach (now sold by MSI, a vendor on the forum), or Rallitek. Link to comment Share on other sites More sharing options...
thestratomaster Posted May 10, 2010 Author Share Posted May 10, 2010 Cool cool. I think the ralliteks might do the trick for me. I just wanted to make sure it wouldn't mess anything up to leave the stock struts on. I'd rather replace those when I need to. How long do struts last? Link to comment Share on other sites More sharing options...
N.sane Posted May 10, 2010 Share Posted May 10, 2010 There's too many variables to say exactly how long they last for. Basically, if you go over a speed bump, and the car bounces up and down a few times before it settles again is a good sign. That basically means the springs are doing all the work lol. Link to comment Share on other sites More sharing options...
thestratomaster Posted May 10, 2010 Author Share Posted May 10, 2010 haha...alright Link to comment Share on other sites More sharing options...
