carr80 Posted May 1, 2010 Share Posted May 1, 2010 My 97 lgt alarm is possesed it will go off when the car is parked unlocked or locked. Is there a way to disable the alarm and still have the keyless entry? Neighbors are getting pretty mad! Link to comment Share on other sites More sharing options...
whos_that_guy Posted May 1, 2010 Share Posted May 1, 2010 just pull the fuse but idk about the keyless entry tho Link to comment Share on other sites More sharing options...
Zues Marine Posted May 1, 2010 Share Posted May 1, 2010 pull the plug on the siren Link to comment Share on other sites More sharing options...
something different Posted May 2, 2010 Share Posted May 2, 2010 if it is the real subaru unit, there is a 4 wire plug on the unit for shock sensor. just unplug it. everything else will still work. the unit should be above the inside fuse/relay box. tom Link to comment Share on other sites More sharing options...
carr80 Posted May 12, 2010 Author Share Posted May 12, 2010 Ill try it thanks Link to comment Share on other sites More sharing options...
