SubyDude555 Posted May 1, 2010 Share Posted May 1, 2010 Do I need these brackets when I install rear Brembos on a Legacy? http://i596.photobucket.com/albums/tt49/SubyStud555/Brembos-1.jpg Link to comment Share on other sites More sharing options...
Darkness of Death Posted May 1, 2010 Share Posted May 1, 2010 i believe there was a couple of vendors here that made brackets for the rear brembos to adapt to our cars. this is probably because the ones in the picture wont fit our cars - assuming they are stock off the STi itself Link to comment Share on other sites More sharing options...
PhilT Posted May 1, 2010 Share Posted May 1, 2010 The brackets are anti vibration dampers, and no you don't need them. You will however, need adapter brackets and other work to get them to fit onto the Legacy. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
darkside Posted May 1, 2010 Share Posted May 1, 2010 Avoturboworld.com or Fredbeansparts has the rear brembo adapter brackets for about $275 got mine 2 weeks ago. I shopped around brembo wants 600 for custom brackets Link to comment Share on other sites More sharing options...
gdawrx Posted July 2, 2010 Share Posted July 2, 2010 darkside: I can't seem to find them on their sites, could you link me? Link to comment Share on other sites More sharing options...
rnstein69 Posted July 2, 2010 Share Posted July 2, 2010 MachV should have them as that is where I got mine. I found the link to the rear caliper relocation bracket for a WRX... this will not work for the LGT, but it looks very similar: http://www.fastwrx.com/retwcaad.html You can call them and see if they still carry it. Link to comment Share on other sites More sharing options...
Leonardo Posted July 23, 2010 Share Posted July 23, 2010 I just need to know how much to grid off for the screw to clear the suspension part. Link to comment Share on other sites More sharing options...
berkshire40 Posted July 23, 2010 Share Posted July 23, 2010 i need rear calipers lol Mod list & photos _ Link to comment Share on other sites More sharing options...
BAC5.2 Posted July 23, 2010 Share Posted July 23, 2010 I just need to know how much to grid off for the screw to clear the suspension part. Trial and error. Just take a little off at a time! [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Leonardo Posted July 23, 2010 Share Posted July 23, 2010 I only have a Dremel. Wonder how many bits I will need!!! Link to comment Share on other sites More sharing options...
FredBeans Posted July 23, 2010 Share Posted July 23, 2010 I used this tungsten carbide bit with my dremel and it made quick work out of the aluminum trailing arms. Maybe 5 minutes per side and another 2 minutes with a sanding drum to smooth it out. http://mdm.boschwebservices.com/MDMCache/English%20%5BUS%5D/t06/0000000/r00070v1.jpg Link to comment Share on other sites More sharing options...
Leonardo Posted July 23, 2010 Share Posted July 23, 2010 If I only had aluminum arms! Link to comment Share on other sites More sharing options...
FredBeans Posted July 23, 2010 Share Posted July 23, 2010 It will work fine on steel, probably better. Aluminum is soft and gums up the flutes of a cutter like this. Link to comment Share on other sites More sharing options...
Leonardo Posted July 25, 2010 Share Posted July 25, 2010 Got it at Lowe's and I'm starting install in a bit. Link to comment Share on other sites More sharing options...
BAC5.2 Posted July 26, 2010 Share Posted July 26, 2010 But you grind the steel knuckle, not the aluminum arms, right? [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
FredBeans Posted July 26, 2010 Share Posted July 26, 2010 Whether the trailing arm is made of aluminum or steel it seems that some grinding is needed to clear the top bolt for Brembo adapters. Link to comment Share on other sites More sharing options...
ebpda9 Posted July 27, 2010 Share Posted July 27, 2010 i got some 06 wrx rear calipers that i want to install. However looking into replacing the backing plate for the brakes. They are only about $80/side, so it comes out cheaper than the brackets. I assume the STI and the wrx use the same backing plate, or at least the positioning of the caliper is the same Link to comment Share on other sites More sharing options...
