holdenspecb Posted April 29, 2010 Share Posted April 29, 2010 How far can you push the stock 06 injectors. I believe they are side feed correct? Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted April 29, 2010 Share Posted April 29, 2010 Side feed yes, you can push them to 100% IDC. Power wise, 270-280whp depending on tuner, set up. Link to comment Share on other sites More sharing options...
biz77 Posted April 29, 2010 Share Posted April 29, 2010 Oh, I've seen them go past 100%. Wouldn't recommend it! Link to comment Share on other sites More sharing options...
holdenspecb Posted April 29, 2010 Author Share Posted April 29, 2010 I'm at about 88-90 with a vf/40 18g about 18 psi thanks for the info. Link to comment Share on other sites More sharing options...
boost4life Posted May 2, 2010 Share Posted May 2, 2010 safely in the 90% range oems are underated..my wrx was running into the 90's no problems Link to comment Share on other sites More sharing options...
ktmrider Posted May 2, 2010 Share Posted May 2, 2010 General rule o thumb, 80% is the line where most reputable tuners will suggest an upgrade. Above that, especially with our glass pistons, there is little margin for error or change ( temp, atmosphere, fuel quality, etc ). Link to comment Share on other sites More sharing options...
