BruceBruce Posted April 27, 2010 Share Posted April 27, 2010 So im switching injector from cyl 3 to cyl 2. I removed the radiator reservoir above #3 and zip tied everything out of the way. I was about to start taking off the connectors to the injectors when i remembered i forgot to empty the fuel lines. Is there any trouble with removing them anyway besides a little spilled gas? Also when switching the injectors is there an o-ring i need replacing or anything like that or is it simply move over to other injector spot and go? Thanks for your help guys. This is my first attack at this but i cant afford to pay a mechanic right now so im just going at it, and looking at vacation pics helps though. Link to comment Share on other sites More sharing options...
ktmrider Posted April 27, 2010 Share Posted April 27, 2010 ^^ There are great write-ups in the How To/Mainenance sections. Pics included! Link to comment Share on other sites More sharing options...
BruceBruce Posted April 27, 2010 Author Share Posted April 27, 2010 oh sweet Link to comment Share on other sites More sharing options...
BruceBruce Posted April 28, 2010 Author Share Posted April 28, 2010 p.s. theres no great write up at all. well i didnt find one at least. But i removed the inj without emptying the lines of fuel. worked fine. Side not the misfire moved with inj! Bingo bango found you! you little f'er misfire. Now to find a replacement. Link to comment Share on other sites More sharing options...
