CoolWater Posted April 23, 2010 Share Posted April 23, 2010 My 90 Legacy won't turn-over. Installed new starter. Battery power is good. When turning key, I get a click. Sometimes it starts - other times just the click. Has been going on for about 30 days. Thoughts? I've had car for 10 years and have been very happy with it. Link to comment Share on other sites More sharing options...
Platinum_Racing Posted April 24, 2010 Share Posted April 24, 2010 Battery cables? Ground wires? These are the most common issues when diagnosing a problem with a car not cranking over. You already took care of the battery, so at least that's out of the way. I'd replace the battery terminal leads, then remove the ground wires and clean the wires and chassis where the wire bolts onto. Link to comment Share on other sites More sharing options...
silver03 Posted April 24, 2010 Share Posted April 24, 2010 ^^^exactly, I 've been through this a number of times. Good advice. Link to comment Share on other sites More sharing options...
CoolWater Posted April 29, 2010 Author Share Posted April 29, 2010 Thanks guys. Tried cleaning the wires. I think it may be the ignition switch. Any recommendations on where I can find an after-market ignition switch for this year car? Thanks Link to comment Share on other sites More sharing options...
