bprman333 Posted April 23, 2010 Share Posted April 23, 2010 I tried make my own cold air intake because if when a got one that didnt use most the stock tubing it wouldnt even start. So, I cut the screen off the front of the thing that holds the sensor and put a tube over it and then a cone filter. Sometimes if i really put the petal to the floor it will sputter and wont go above 1500 rpm. Did i ruin it? sugesstions please Link to comment Share on other sites More sharing options...
Zues Marine Posted April 23, 2010 Share Posted April 23, 2010 how did you get the cone to stay on the face of the maf sensor .. you should have used a MAF Sensor adapter.. its like $6 Link to comment Share on other sites More sharing options...
whos_that_guy Posted April 23, 2010 Share Posted April 23, 2010 well that was kinda stupid to do o.0 some things u shouldnt do cheap http://www.cosmoracing.com/productinfo.asp?cid=150&pid=1812 http://www.cosmoracing.com/productinfo.asp?cid=226&pid=1562 2 different one, short ram and interfender one Link to comment Share on other sites More sharing options...
bprman333 Posted April 23, 2010 Author Share Posted April 23, 2010 i got a piece of tubing that you make cold air intakes out of and there was enough room after i cut the front off to just slide it off Link to comment Share on other sites More sharing options...
subikid90 Posted April 23, 2010 Share Posted April 23, 2010 Pictures of this would help. Like zues said you should be using a MAF adapter. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
bprman333 Posted April 23, 2010 Author Share Posted April 23, 2010 ok ill post some tomorrow. has anyone used the cosmo short ram. im thinking about getting one of those Link to comment Share on other sites More sharing options...
ggreene Posted April 24, 2010 Share Posted April 24, 2010 Fabricated hybrid intake, (1996 Legacy), - Option Racing short ram was hacked up for this project, picked it because it had three vacuum outlets, (just perfect). - 3" gradual curve, (w. 3" silicone couplers, - 3" to 2.75" at throttle body). - extends much further back toward firewall - Volume/velocity works well w. header, (no "one mod" will make much of a difference). - This set-up, (there is a write-up somewhere in NASIOC), works for me. 1. - MAF must be operational. 2. - All vacuum lines must be operational, (most especially the IAC, without this the engine will not run at all). 3. - Remember the "air-in - air out" principle - intake AND exhaust. 4. - Stock 7x11 panel filter will flow more air than I'll ever need, unless I somehow go over 250hp. (which is not likely), - (a good Denso unit works well). 5. - Reset ECU, have air/fuel mixture checked, and you're good to go, (of course results may vary) - I have a good working 4EAT, other mods, but these work together for much increased HP. - Lightweight BD body! - I surprise alot of people, esp. Hondas & newer Subarus. Link to comment Share on other sites More sharing options...
