Maddie08 Posted April 14, 2010 Share Posted April 14, 2010 Do aftermarket springs exist that do NOT drop the car at all? I want to have a firmer spring (and possibly more durable) that will not change the height at all. Any ideas LGT.com team? Link to comment Share on other sites More sharing options...
Th3Franz Posted April 14, 2010 Share Posted April 14, 2010 All the springs lower the car at least a little bit. I think Eibach/Rallitek springs lower the car by less than 1 inch though. You could look into running different top hats or spacers to negate the drop from the springs. Even my 88 year-old grandmother can get into my car that is lowered on pinks and I drive through deep snow in winter, so the ride height with conservative lowering springs is not a big deal -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
RabidWombat Posted April 14, 2010 Share Posted April 14, 2010 If you put a spacer in under the spring it wouldn't lower the car but would be stiffer. I'm not sure this is really practical or if such a spacer exists, but its theoretically possible. Link to comment Share on other sites More sharing options...
dr_sharp Posted April 14, 2010 Share Posted April 14, 2010 they exist for rear and alot of people use them. paranoid fabrications. I'm sure you could find a wrx front set that would fit or ask paranoid fabs to make you a custom set for front. lol Link to comment Share on other sites More sharing options...
Meshanks07 Posted April 14, 2010 Share Posted April 14, 2010 I have Ralliteks and very happy with them. Lowered the car a bit but gives it a firmer feel. Drop is less than an inch, looks like stock which I wanted. Link to comment Share on other sites More sharing options...
Mindspin311 Posted April 14, 2010 Share Posted April 14, 2010 RCE T1's are only like 1/2" drop Link to comment Share on other sites More sharing options...
sactojesse Posted April 14, 2010 Share Posted April 14, 2010 JDM LGT springs are the only ones that come to mind, but the front springs are designed to work w/ Bilstein/Spec B style top hats. You'll actually raise the front end by around 1/2" - 5/8" if you run a JDM LGT front spring with a USDM KYB-style top hat/strut combo. Link to comment Share on other sites More sharing options...
CTATV Posted April 14, 2010 Share Posted April 14, 2010 coilovers dont have to lower the car... you can ajust the ride height Link to comment Share on other sites More sharing options...
MeoW71 Posted April 15, 2010 Share Posted April 15, 2010 Ground control coilovers. Talk to them about what you want to do and I'm sure they could come up with a spring combination that will be stiffer and keep your stock height. Link to comment Share on other sites More sharing options...
unlimited6986 Posted April 15, 2010 Share Posted April 15, 2010 Yea i would say jdm springs. I think i have some from my rev A's Link to comment Share on other sites More sharing options...
Th3Franz Posted April 15, 2010 Share Posted April 15, 2010 Ground control coilovers. Talk to them about what you want to do and I'm sure they could come up with a spring combination that will be stiffer and keep your stock height. They make a set for the LGT? Last I checked they were not interested. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
Maddie08 Posted April 16, 2010 Author Share Posted April 16, 2010 Going to look into a few of these. Thanks for all the comments so far! Link to comment Share on other sites More sharing options...
Th3Franz Posted April 16, 2010 Share Posted April 16, 2010 I heard a song once it went something like "drop it low girl, drop it drop it low girl" -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
dr_sharp Posted April 16, 2010 Share Posted April 16, 2010 I heard a song once it went something like "drop it low girl, drop it drop it low girl" I think now would be an approxpriate time to post a picture of your car lol Link to comment Share on other sites More sharing options...
Th3Franz Posted April 16, 2010 Share Posted April 16, 2010 I think now would be an approxpriate time to post a picture of your car -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
katalyst Posted April 17, 2010 Share Posted April 17, 2010 what if you just replaced your struts with koni inserts? you would still be at stock height but have firmer dampers Link to comment Share on other sites More sharing options...
NorthernVTGT Posted April 29, 2010 Share Posted April 29, 2010 In this vein... Many of the roads where I live are UNBELIEVABLY bad. I have to avoid one in particular to save my wheels. Dirt roads would be better. Given my geography, I would like to go with a longer-travel but better-damped ride. I do more fast back road touring than anything else. How about a strut suggestion to pair with stock (wagon) springs? The KYBs are just about done, and I would like to order something to have installed when the new clutch goes in. Koni's? What about HDs? What's an acceptable pairing with stock springs? Link to comment Share on other sites More sharing options...
Th3Franz Posted April 29, 2010 Share Posted April 29, 2010 Konis with stock top hats or Bilstein HD with Spec B top hats. They will work fine with stock springs but would be better matched with pinks, Rallitek, or MSI springs and you will still have lots of travel In fact, I bottom out a lot less with JDM GT Bilsteins + pinks than when I was on stock suspension -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
