bigog Posted April 13, 2010 Share Posted April 13, 2010 I hav 99 outback, 2.5, 214,000 mil., head gaskets done at 200,000. Heat gauge goes to max temp. after about 2 miles of driving. Temp. drops after, stop, with fan on. Upper hose hot. lower hose, and heater hoses cold. Able to remove radiator cap(cold.) No heat. Flushed radiator, changed thermostat. Water pump? Help! Every mechanic wants to the head gaskets again. No leaks detected, oil ok, exhaust ok. Link to comment Share on other sites More sharing options...
subikid90 Posted April 13, 2010 Share Posted April 13, 2010 What thermostat did you replace it with? If it was not the expensive OEM one from the stealership then it wont work. I have tried NAPA and Carquest thermostats made for my engine and both sucked and just caused overheating. I think the stealership want $17ish for the part and then a couple more bucks for the gasket. Doesn't sound like you have bad headgaskets, you just have a bad thermostat. Also did you make sure to get all of the air pockets out of the system? -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
kaz98gt Posted April 14, 2010 Share Posted April 14, 2010 could very well be an air pocket. too many times this has happened, not to call you foolish or anything. but if you don't bleed absolutely every last drop out (figured this out the hard way), it will cause problems. but yep thermostat is a good place to start aftre you make sure the coolant system is bled properly. Link to comment Share on other sites More sharing options...
bigog Posted April 14, 2010 Author Share Posted April 14, 2010 Thanks. Will bleed system again, and get thermostat from dealership. But, first I'll test the water pump by running car without thermostat to see if I get coolant flow. Will let you know what happens. Link to comment Share on other sites More sharing options...
bigog Posted April 23, 2010 Author Share Posted April 23, 2010 Problem solved. New thermostat, lower hose, radiator cap, 1 hour coolant bleed. No more temperature spiking. Now I have a radiator leak. Fixed that with leak repair. Will get new radiator if that fails. Tks for help. Link to comment Share on other sites More sharing options...
subikid90 Posted April 23, 2010 Share Posted April 23, 2010 That is good to hear. For s**ts and giggles did you test the old thermostat to see if that was the culprit of this problem? -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
LucaBrasi Posted April 23, 2010 Share Posted April 23, 2010 I was also going to say air in the system. I recently brought my car to get maint. done and when I was driving it home I had a simmilar issue. Turns out they had to bleed the air out of the system. Link to comment Share on other sites More sharing options...
ncbill Posted April 26, 2010 Share Posted April 26, 2010 When I got my head gaskets replaced last year the dealership replaced every seal, belt, hose, water pump, and also swapped the radiator. I suspect when the engine's open for the gasket replacement that's the way to go, even if you're DIY. Link to comment Share on other sites More sharing options...
kaz98gt Posted April 26, 2010 Share Posted April 26, 2010 +1 while everything's out, do all the gaskets. absolutely no question...no one wants to have to tear it apart again once a vcg goes or something. glad to hear the problem's fixed though! Link to comment Share on other sites More sharing options...
bigog Posted April 27, 2010 Author Share Posted April 27, 2010 did test old thermostat, it was bad Link to comment Share on other sites More sharing options...
Homo Sapien Posted April 27, 2010 Share Posted April 27, 2010 Can someone explain how to bleed cooling system? I am experiencing problems and will try this before more expensive options. 98 legacy gt limited Link to comment Share on other sites More sharing options...
