rSTimpreza Posted April 8, 2010 Share Posted April 8, 2010 I have 98 legacy outback limited im wondering if the 07 WRX sedan suspension (spring,struts,tophats) will fit perfectly without my rear sagging and have no problem aligning it at the alignment shop? pls help Link to comment Share on other sites More sharing options...
Zues Marine Posted April 9, 2010 Share Posted April 9, 2010 nothing from an 05+ wrx/sti will work because subaru changed bolt patterns on struts, hubs, and some other stuff, all of the 93-04 impreza/wrx/sti stuff will work tho, you just need to mix and match parts like tophats and spring perches in some applications for them to be able to bolt up Link to comment Share on other sites More sharing options...
