dr_sharp Posted April 5, 2010 Share Posted April 5, 2010 So I purchased an STi flywheel and pressure plate from a member here. What else do I need to bolt this onto my 6spd? This is probably the one part of a car that I know the least about. I'm sorry I know this is going to be painful and I have my full flame suit on lol Link to comment Share on other sites More sharing options...
custom_junky Posted April 6, 2010 Share Posted April 6, 2010 to put it simply, you need: flywheel (resurfaced if used) clutch pressure plate(should be new) pilot and through out bearing alignment tool that's it, and use the alignment tool to hold everything in place while you bolt it on the engine/flywheel (i'm assuming you can look up the steps via service manual to install a new flywheel and clutch assembly) Link to comment Share on other sites More sharing options...
Darkness of Death Posted April 6, 2010 Share Posted April 6, 2010 that was pretty straight forward ~ Link to comment Share on other sites More sharing options...
dr_sharp Posted April 6, 2010 Author Share Posted April 6, 2010 to put it simply, you need: flywheel (resurfaced if used) clutch pressure plate(should be new) pilot and through out bearing alignment tool that's it, and use the alignment tool to hold everything in place while you bolt it on the engine/flywheel (i'm assuming you can look up the steps via service manual to install a new flywheel and clutch assembly) So is 3k miles considered new? lol Link to comment Share on other sites More sharing options...
custom_junky Posted April 6, 2010 Share Posted April 6, 2010 for what? clutch? flywheel? pressure plate? Link to comment Share on other sites More sharing options...
dr_sharp Posted April 7, 2010 Author Share Posted April 7, 2010 pressure plate & flywheel lol Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted April 7, 2010 Share Posted April 7, 2010 So is 3k miles considered new? Depends on perspective. IMO "new" is uninstalled, never installed. Link to comment Share on other sites More sharing options...
custom_junky Posted April 7, 2010 Share Posted April 7, 2010 pressure plate & flywheel to be honest i've always been under the philosophy that a new clutch will get a new pressure plate, bearings, and at minimum reserficed flywheel...now granted with only 3 grand on those two items, i can't see much hurt in just putting it all together, but without the history of abuse the flywheel and pressure plate had during those 3 thousand miles, i can't say for sure Link to comment Share on other sites More sharing options...
dr_sharp Posted April 7, 2010 Author Share Posted April 7, 2010 It seems like the bearings and clutch disc would be the only items that could really get damaged in 3k miles... which are the items that I'm buying new. I can get the flywheel resurfaced without much issue... how would the pressure plate wear down with mileage? lol Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted April 8, 2010 Share Posted April 8, 2010 It seems like the bearings and clutch disc would be the only items that could really get damaged in 3k miles... which are the items that I'm buying new. I can get the flywheel resurfaced without much issue... how would the pressure plate wear down with mileage? Doc, can you post some pics of the surface of the flywheel / clutch so those in the know (NOT ME) can chime in? I bet someone has seen a couple. Link to comment Share on other sites More sharing options...
custom_junky Posted April 8, 2010 Share Posted April 8, 2010 It seems like the bearings and clutch disc would be the only items that could really get damaged in 3k miles... which are the items that I'm buying new. I can get the flywheel resurfaced without much issue... how would the pressure plate wear down with mileage? this is true, and like i said i highly doubt that the flywheel or pressure plate is damaged or in need of resurfacing (in the case of the flywheel)...to answer your question about the pressure plate, it has a metal surface similar to a flywheel, and just like a flywheel, it too can be hot spotted and have the same wear patterns...but in 3 thousand miles, it is highly unlikely to have been damaged at all...but like i said before i'm pretty anal about that kind of stuff since i'm so hard on my vehicles (it is more or less just to allow me to sleep better at night, thats all) Link to comment Share on other sites More sharing options...
dr_sharp Posted April 10, 2010 Author Share Posted April 10, 2010 this is true, and like i said i highly doubt that the flywheel or pressure plate is damaged or in need of resurfacing (in the case of the flywheel)...to answer your question about the pressure plate, it has a metal surface similar to a flywheel, and just like a flywheel, it too can be hot spotted and have the same wear patterns...but in 3 thousand miles, it is highly unlikely to have been damaged at all...but like i said before i'm pretty anal about that kind of stuff since i'm so hard on my vehicles (it is more or less just to allow me to sleep better at night, thats all) I gotcha. Thanks for the info. Let me snap some pictures of the flywheel/pressureplate. I picked up the new throwout bearing and clutch disc from the dealer this week. lol Link to comment Share on other sites More sharing options...
dr_sharp Posted April 10, 2010 Author Share Posted April 10, 2010 I am idiot... pictures here all along: http://legacygt.com/forums/showthread.php/fs-ma-sti-fly-and-133892.html lol Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted April 10, 2010 Share Posted April 10, 2010 BUMP, anyone who has seen multiple used clutch/fw chime in here please? Link to comment Share on other sites More sharing options...
custom_junky Posted April 12, 2010 Share Posted April 12, 2010 well shit...the pics are blocked at work...i'll try and remember to look through them tonight after work though Link to comment Share on other sites More sharing options...
dr_sharp Posted April 13, 2010 Author Share Posted April 13, 2010 maybe if I bump the thread it will help you remember? It really doesn't matter at this point; what's done is done and if the flywheel needs resurfaced then whoever installs the clutch will resurface it. As I said the clutch disk and bearings are new from the dealer. The only thing in question really is the pressure plate which I feel is fine. lol Link to comment Share on other sites More sharing options...
custom_junky Posted April 13, 2010 Share Posted April 13, 2010 with the pressure plate, just like the flywheel, all you really need to be weary of is discoloration (hot spots) and deep scoring...if there are none, then there is no need to be worried Link to comment Share on other sites More sharing options...
