Chuckadian Posted April 5, 2010 Share Posted April 5, 2010 Hey guys, I had my 97 lgt in the air doing an oil change. I have had a strange metallic rattle coming from in front of the steering wheel somewhere, I think near the steering rack and front axles. While it was in the air I went around shaking all the parts I thought could make noise. All I found was a little play in each axle, right where it comes out of the transmission. It moves back and forth, maybe 1/8" on each side. Is this normal for our cars? If anyone is going to have their lgt in the air in the next day or two and could check theirs, that would be great! Link to comment Share on other sites More sharing options...
DN1911 Posted April 5, 2010 Share Posted April 5, 2010 rotational movement or lateral towards the wheel? Link to comment Share on other sites More sharing options...
kaz98gt Posted April 6, 2010 Share Posted April 6, 2010 if it's lateral (in and out in relation to the transmission), that's not good. there should be a pin binding the halfshaft to the spline of the transmission so as to not allow that movement in and out. if it moves, check the hole that should be in the shaft to see if there's a pin. if there isn't, or there isn't a hole, you need a new shaft. subaru is the only car I know that has a pin setup for connecting halfshafts to the transmission, but I'd imagine it's for minimizing that kind of play. Link to comment Share on other sites More sharing options...
Chuckadian Posted April 6, 2010 Author Share Posted April 6, 2010 Yeah, it's lateral. I'll have to have a closer look at it tomorrow, and ill look for that pin. Thanks! Link to comment Share on other sites More sharing options...
kaz98gt Posted April 6, 2010 Share Posted April 6, 2010 sounds good keep us posted. Link to comment Share on other sites More sharing options...
DN1911 Posted April 6, 2010 Share Posted April 6, 2010 there is a chance that the pin may have sheared, might have to pull the axle and tap the pin out of the output shaft. would usually be a sign of a major malfunction.... Link to comment Share on other sites More sharing options...
Chuckadian Posted April 6, 2010 Author Share Posted April 6, 2010 What kind of problems could I be looking at? Link to comment Share on other sites More sharing options...
kaz98gt Posted April 6, 2010 Share Posted April 6, 2010 hmm...if that pin sheared, there was some tremendous lateral stress on that axle. any rock crawling recently? Â If that pin is beat, just pop it out and put in a new one. no need to pull the whole axle and examine it; just check the boots, shaft, etc. If it doesn't drive better once you swap pins, then you gotta tear down the system. Link to comment Share on other sites More sharing options...
Chuckadian Posted April 6, 2010 Author Share Posted April 6, 2010 Right on, I'll look into it after class today. The axle seal is seeping just a bit, so if I need to tear down the whole thing I'll do that too. Â Is this the part I need? Thanks! http://img.eautopartscatalog.com/live/W01331643567EMP.JPG Link to comment Share on other sites More sharing options...
kaz98gt Posted April 6, 2010 Share Posted April 6, 2010 Yep that looks about right. be absolutely sure that the axle is in the right spot because once you hit the pin part of the way in and realize it's not lined up, it's a bitch to get out. experience sucks, but glad I can help Link to comment Share on other sites More sharing options...
Chuckadian Posted April 6, 2010 Author Share Posted April 6, 2010 So the pin is still there, but it looks like it might not be in right. Its not centered in the axle, and looks to be a little crushed. Could that be enough to cause it? What else could cause play in that part? Link to comment Share on other sites More sharing options...
subikid90 Posted April 6, 2010 Share Posted April 6, 2010 If you are getting about an 1/8" play I would think that the pin being crushed could cause that amount of play. -Subikid90Â 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Chuckadian Posted April 6, 2010 Author Share Posted April 6, 2010 I have the pins on order, I should have them on friday, I'm hoping that fixes it Link to comment Share on other sites More sharing options...
subikid90 Posted April 6, 2010 Share Posted April 6, 2010 Its always worth a try because I'm sure the pins didn't cost much. Can you watch the pin and see if it moves around in the hole when you moving the axles around? -Subikid90Â 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Chuckadian Posted April 6, 2010 Author Share Posted April 6, 2010 Yeah, I didn't see much movement in the pin Link to comment Share on other sites More sharing options...
kaz98gt Posted April 6, 2010 Share Posted April 6, 2010 can you see the axle move in and out of that spline when you jostle it? if you can it's definitely the pin. Link to comment Share on other sites More sharing options...
Chuckadian Posted April 7, 2010 Author Share Posted April 7, 2010 Whats the best way to push the old one out and press the new one in? Link to comment Share on other sites More sharing options...
kaz98gt Posted April 7, 2010 Share Posted April 7, 2010 drift pin probably. you've got a lift so it makes things easier to get to, but yeah i'd go drift pin and a mallet or hammer. have the shaft supported somehow too. Link to comment Share on other sites More sharing options...
ineedmorepsi Posted April 8, 2010 Share Posted April 8, 2010 You know thanks to you guys I found out I'm missing a damn driver side axle pin. WTH do I get oneat? I've already did 2 Auto-X events for the season so far without a pin and I'm surprised nothing happened yet. The axle moves back and forth from trans to hub about half an inch or so. Link to comment Share on other sites More sharing options...
kaz98gt Posted April 8, 2010 Share Posted April 8, 2010 wow you've gotten off really really lucky! I'd imagine driving with that play puts stress on the tranny/diff with the differences in length; maybe I don't know the mechanics behind it too much, but that gap has got to go. good luck, glad you caught it! Link to comment Share on other sites More sharing options...
Chuckadian Posted April 8, 2010 Author Share Posted April 8, 2010 Lucky catch! I got mine from the dealership, theyre on order. About $2 each. Or check http://www.autohausaz.com its called a CV roll pin on that website. Link to comment Share on other sites More sharing options...
gathermewool Posted April 8, 2010 Share Posted April 8, 2010 Also known as a spring pin. I got mine at the dealer as well. FWIW, the spring pin I got from the dealer seemed to be higher quality than the pin that came with my new axle. '15 FB25 Magnatec 0W-20 + FU filter (70,517 miles) RSB, Fr. Strut Bar, Tint, STI BBS, LED er'where Link to comment Share on other sites More sharing options...
