LGTspecB1657615261 Posted April 3, 2010 Share Posted April 3, 2010 The dealer I bought my car from thought it was a great idea to install pinstripes. Most of it came off well, but one section left a tone of glue. Not sure why it was different than the other sections. What off the shelf cleaner will help get it off, but not damage the clear coat? OCD where are you!? Help please Thanks! Link to comment Share on other sites More sharing options...
LegacyGTBiggie Posted April 3, 2010 Share Posted April 3, 2010 CLAYBAR!!! I did mine on a hot day. they washed it a LOT until i couldnt see any. then clayed and waxed. Link to comment Share on other sites More sharing options...
fx4me Posted April 3, 2010 Share Posted April 3, 2010 Clay bar, polishing compound (mine is Turtle Wax brand), or goo-gone for more stubborn residue. Link to comment Share on other sites More sharing options...
km580 Posted April 3, 2010 Share Posted April 3, 2010 WD40 works good too. Fat people are hard to kidnap!!! Link to comment Share on other sites More sharing options...
LGTspecB1657615261 Posted April 4, 2010 Author Share Posted April 4, 2010 thanks guys! Link to comment Share on other sites More sharing options...
OCDetails Posted April 5, 2010 Share Posted April 5, 2010 WD40 works good too. That's the trick right there. If you are dealing with adhesive residue then you'll want to use a solvent. Mineral spirits are great. WD-40 will get adhesive off in no time and it is fairly safe on your paint. I would be careful on freshly painted panels or any self painted pieces, but on typical cured automotive paint you really have very little to worry about. Just wash the area after you are done and use a soft towel. oh, the best way to apply it without making a mess is to soak a towel with it and then dab it on. let it soak for a few seconds before rubbing. it helps if you heat the adhesive up a little too before you dab it. Don't get the heating and dabbing mixed up. WD-40 is highly flammable and combustible. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
LGTspecB1657615261 Posted April 5, 2010 Author Share Posted April 5, 2010 I am still working at one panel. Its really on there. For some reason just 1 section of the stripes left the glue on the car. All other sections, it came right up. The WD 40 worked great, except nothing on this one panel! It did not do much, even after soaking it. Patience and eventually it will all come up with my nail behind a microfiber rag. Link to comment Share on other sites More sharing options...
km580 Posted April 5, 2010 Share Posted April 5, 2010 WD40 is great for a lot of things. A long time ago, elderly people thought that spraying WD40 on your joints would cure arthritis..LOL Fat people are hard to kidnap!!! Link to comment Share on other sites More sharing options...
OCDetails Posted April 5, 2010 Share Posted April 5, 2010 ^^ That was probably until they discovered that Windex is much more effective. lol _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
km580 Posted April 5, 2010 Share Posted April 5, 2010 http://www.wd40.com/uses-tips/ Fat people are hard to kidnap!!! Link to comment Share on other sites More sharing options...
LGTspecB1657615261 Posted May 5, 2010 Author Share Posted May 5, 2010 WD 40 is not working at all. I need something stronger, but I do not want to mess up my clear coat or make it blurry. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted May 5, 2010 Share Posted May 5, 2010 WD 40 is not working at all. I need something stronger, but I do not want to mess up my clear coat or make it blurry. You could try GooGone2 but definately not GooGone. There is a big difference but even with GooGone2 I would test it on a underside bumper section to make sure it causes no clouding. I have used it to clean up beutyl residue inside door panels and in interior painted sections on my old Honda to no ill effects. Again please try it on a underside bumper section to be certain. I have not tried this product on LGT paint but it is a orangeoil product. Link to comment Share on other sites More sharing options...
mattg Posted May 5, 2010 Share Posted May 5, 2010 ^ That might work. I would try PPG DX 330 wax and grease remover. If that didn't work i would move straight to paint thinner. As long as you're working on a clear coated surface it will work just fine. If there is a little haze left behind it will rub/buff right out. Soak with thinner, scrape with finger nail, rub with thinner soaked rag. Link to comment Share on other sites More sharing options...
Brady Posted May 7, 2010 Share Posted May 7, 2010 Wait, have you tried the claybar yet? Generally speaking, if a claybar won't clean the surface of your paint, nothing will. There isn't much else safer than a claybar either. Link to comment Share on other sites More sharing options...
dudeondacouch Posted May 7, 2010 Share Posted May 7, 2010 rubbing compound and elbow grease. /thread Link to comment Share on other sites More sharing options...
lgtgirl06 Posted May 7, 2010 Share Posted May 7, 2010 Bug and Tar remover works well also. Heat the adhesive first though it will help a lot. Link to comment Share on other sites More sharing options...
TRS Posted May 8, 2010 Share Posted May 8, 2010 I've had good success using 3M Adhesive & Wax Remover for left-over adhesive residue. http://3m.hillas.com/GetThumbNail.aspx?Type=Item&Image=13847&Size=large Ingredients: SOLVENT NAPHTHA (PETROLEUM), LIGHT ALIPHATIC XYLENE ETHYLBENZENE TOLUENE BENZENE As mentioned earlier, softening up the residue with heat eases removal (hair dryer, gentle use of heat gun, or just park it so that section gets direct sun on a warm day). Link to comment Share on other sites More sharing options...
LGTspecB1657615261 Posted May 8, 2010 Author Share Posted May 8, 2010 Thanks guys! Link to comment Share on other sites More sharing options...
Mungo Posted June 5, 2010 Share Posted June 5, 2010 I had to replace the bump strips (side moldings) on my VW a few years back. It was insanely difficult to remove all the adhesive left over. I ended up finding this wheel type attachment that fits on the end of a drill. It "rubs" the adhesive right off, making clean up far easier via other means. If you have a lot to remove I would recommend looking into this. The wheel is somewhat rubbery, somewhat "eraser-like". Link to comment Share on other sites More sharing options...
badwolf Posted June 6, 2010 Share Posted June 6, 2010 Available at AutoZone it's called "Sticker Shock". It comes in a small grey aerosol can and will also remove 3M adhesive tape with no harm to the clear coat. Link to comment Share on other sites More sharing options...
