Woodstock Posted March 31, 2010 Share Posted March 31, 2010 I need help finding leaks:eek:. I currently installed a FMIC and being tuned by infamous. He said that I have a leak in the intake. I don't have an idea or experience to find a leak in the engine area. help please Link to comment Share on other sites More sharing options...
Woodstock Posted April 1, 2010 Author Share Posted April 1, 2010 anybody know how to do boost leak test? I think I hear a whistle noise when accelerating. Link to comment Share on other sites More sharing options...
Waaazooo Posted April 2, 2010 Share Posted April 2, 2010 a leak test can be easy to do. Go buy a short piece of PVC pipe that matches the inlet tubing for your car. I think 2.5" is common for the after MAF portion of the inlet. Also buy an end cap for the pipe. drill and thread in valve for a tire. Place the pressure cap into the inlet portion. Clamp down the hose clamp. Use a tire pump to pressurize the intake system (20-25psi), get soem soapy watter from your moms sink (clean if possible) and wipe down couplers of the whole intake system (FMIC or TMC) you will find a place the bubbles up. Link to comment Share on other sites More sharing options...
Woodstock Posted April 2, 2010 Author Share Posted April 2, 2010 thanks for the info. I was not sure how much pressure I need to let in the system. Link to comment Share on other sites More sharing options...
Waaazooo Posted April 2, 2010 Share Posted April 2, 2010 Well, I would test it at least 5 psi above your target boost pressure. Link to comment Share on other sites More sharing options...
CRAZY KEN Posted April 2, 2010 Share Posted April 2, 2010 ...stop by DPS and talk to Piruz....he is in Gaithersburg...he's open from 10-12 or 10-2! Tell him Ken sent you, CK Link to comment Share on other sites More sharing options...
Woodstock Posted April 3, 2010 Author Share Posted April 3, 2010 ...stop by DPS and talk to Piruz....he is in Gaithersburg...he's open from 10-12 or 10-2! Tell him Ken sent you, CK Thanks! I will. Link to comment Share on other sites More sharing options...
