spect2k Posted March 29, 2010 Share Posted March 29, 2010 I just got a four wheel alignment done at my local tire place that usually does a nice job. They always give a printout with the information (see below). I'm interested in some thoughts about the right rear camber and the comment on the bottom that says it's not adjustable. It is obviously outside of the recommended limit, but it appears that it can't be adjusted? Thoughts?? Link to comment Share on other sites More sharing options...
LowFast Posted March 29, 2010 Share Posted March 29, 2010 It can be adjusted but not directly, they have to jimmy with the toe/caster/camber to make it all work in the rear. The 1.7 is not extreme (mine is 1.5 on the right and 1.2 on the left in the rear) Actually I would run alittle more up front and be happy with the rear, I am currently running about 1.2 neg in the front with no adverse tire wear and much improved handling. Link to comment Share on other sites More sharing options...
