Lotek Posted March 26, 2010 Share Posted March 26, 2010 Im about to hit 150k on my 2000 LGT. Is there a service, and whats it involve? Link to comment Share on other sites More sharing options...
Platinum_Racing Posted March 26, 2010 Share Posted March 26, 2010 Depends on how much money you want to spend. Here are the basic things that I would consider. These may not be right for you depending on when they were done last, but they are a good starting point.... --------------------------------- If its an auto, a transmission flush with new filter. Oil change Spark plugs & wires Fuel filter Tire rotation Brake inspection Radiator flush with new thermostat Front end alignment Top off all fluids... Power steering, brake fluid, washer fluid, ect... (Whatever you don't change or flush) New wipers Inspect U-Joints Inspect timing belt & Whatever else it says to do in the owners manual. Its almost the weekend, hopefully you'll find the time to get some of this done and have fun at the same time. Link to comment Share on other sites More sharing options...
