Vascoobiedude Posted March 21, 2010 Share Posted March 21, 2010 Recently, I noticed the chrome was peeling off my JDM L7 Red emblem grill. So, I decided to take a shot at painting it. Pictures are limited, but heres what I did. Obviously, removing the grill is a given, so I didn't include how to do that. If you havent figured out how to do that, something like this may be over your level anyways. lol. Step 1. Sanding- So, all that peeling, old, nasty looking chrome paint has got to go. Using steel wool or a scotch brite pad would be optimal, but I'm too impatient to spend hours removing paint, so i started with a medium grit sandpaper. Don't rub too hard, or you'll gouge the plastic. Too lite, and your arm will fall off before you're done. It's kinda one of those things you gotta just feel. Once you've roughed up the entire chrome surface (NOT the entire grill yet..), rinse it off to get rid of all the big chunks. Now comes the fun part... WET SANDING!!! I did mine in my bathtub, but you can do it outside with a hose, and/or bucket. The key here is light pressure, and lotsa water. A very fine grit wetsanding paper will take time to get the remaining paint off, but the results will be very nice indeed. If you did rub too hard with the coarse paper, dont fret. The wet sanding will smooth those gouges out... eventually. Once you have all the chrome off, go over the entire grill, or at least wherever you want to paint, wet sanding to make sure you have a smooth, paint friendly surface. Step 2. CLEAN!!! As with any painting project, cleaning and prep is paramount to a good outcome. Wash off all the crud you created by sanding, with a CLEAN rag and soap. I used dawn, because it rinses clean and dosent have any of that girly lotion stuff in it that will adhere to the plastic. RINSE, RINSE, RINSE!!! If you think yopu got all the soap off, keep rinsing. Next you'll need to dry it. You can hang and drip dry, put it outside in the sun, or do like me and use a hairdryer. (Again, I'm impatient to a point.) There are alot of nooks and crannys in these things, and it only takes a tiny drop of water to mess up the whole process. So make SURE it is completely dry. Once it is, you're almost ready to paint. Step 3. Masking- This is somewhat tedious... Mask the emblem off with masking tape. Trim off the excess tape LIGHTLY with a razor blade, making sure the entire emblem is covered, but not the surrounding area you want to paint. Tape and paper and other spots you don't want to paint. This should be pretty straight forward, so not a lot of details to cover. Step 4. CLEAN!!! I know you're saying "I already cleaned it, Scoob!" Yes. You did. But, you've also been handling it in the process of drying and masking. So, the oils from your skin have gotten on that freshly sanded raw plastic, and need to come off. Rubbing alcohol and COTTON BALLS will take that right off. No toilet paper, paper towels, or rags, these leave lint. Cotton balls or your girlfriends/wifes/moms cotton makeup pads work great. Rub the entire surface to be painted with plenty of alcohol, and wait for it to dry. Now we're ready to get high! Er, I mean paint! lol. Step 5. Paint- Color, type of paint, etc. is going to be personal preferance, so I'll explain what I did, and why. If you value brain cells, ventilation is important. If you've had a bad week at work, maybe it's not. I started with a light coat of black FILLER PRIMER. This fills in any of the small imperfections that sanding may have left in the plastic. It dries quick, so I had time to smoke a ciggaret, and then it was time to put on coat #2 of primer. I did this simply to ensure uniform coverage. Once that dried, it was color time!!! I wanted satin black, simply because A. I couldn't decide what else would look good, and B. It was easy. lol. Because it was primed, using plastic specific paint wasn't necessary. So, I wen't with Satin black High Heat Rustoleum Grill and BBQ paint. Now, I can hear the jokes already, about wrong kind of grill, can I have a burger, etc. But let me explain... The grill you cook on, stays outside. In the sun. And in the weather. And in the heat. So, naturally, the paint has to withstand those elements. Right? Logically, it makes sense to me that if it works on a BBQ grill, it should be able to hold up to the rain, and sun, and heat of being on the front of my car! Hey.. Makes sense to me... The key here, is to use multiple light coats of paint, allowing just enough time for the surface to be tacky, but not dry, between coats. Too much, and you'll have runs. Too light, and it will be rough to the touch and look. 4 coats later, its time to dry for good! Patience, lazy, etc. i used my trusty hairdryer again, just to get a good solid bake on the top, and then put it back on the car to sun dry. I did this, so that when drying/curing outside, bugs, leaves, etc, wouldn't stick to it. Step 6. Enjoy!! Do not install the grill if you need to drive the car within 24 hours of painting it. This is roughly how long it will take my method to properly cure and dry, to where bugs hitting it won't screw up your new paint. Now for pics!!! Before... Notice the peeling, stained chrome... http://i1029.photobucket.com/albums/y359/vascoobiedude/Scoobie/IMG_3491.jpg In the tub, ready to sand... http://i1029.photobucket.com/albums/y359/vascoobiedude/Parts/photo.jpg Sanded and masked up, ready for primer.. http://i1029.photobucket.com/albums/y359/vascoobiedude/Parts/IMG_3495.jpg Primed, ready for color http://i1029.photobucket.com/albums/y359/vascoobiedude/Parts/photo2.jpg Unmasked, hairdryer cured, ready to go on the car http://i1029.photobucket.com/albums/y359/vascoobiedude/Parts/IMG_3496.jpg Finished, and installed! http://i1029.photobucket.com/albums/y359/vascoobiedude/Parts/IMG_3497.jpg http://i1029.photobucket.com/albums/y359/vascoobiedude/Parts/IMG_3498.jpg Whatcha think?? Link to comment Share on other sites More sharing options...
Blaeven Posted March 22, 2010 Share Posted March 22, 2010 i think i want a USDM front end of my car... Link to comment Share on other sites More sharing options...
Vascoobiedude Posted March 22, 2010 Author Share Posted March 22, 2010 I'll trade ya!!! lol Link to comment Share on other sites More sharing options...
Blaeven Posted March 25, 2010 Share Posted March 25, 2010 done! you send yours over then i'll send you mine! Link to comment Share on other sites More sharing options...
kaz98gt Posted March 25, 2010 Share Posted March 25, 2010 everybody happy! looks sharp scoobie nice job Link to comment Share on other sites More sharing options...
daleyswanson Posted March 25, 2010 Share Posted March 25, 2010 looks killer Link to comment Share on other sites More sharing options...
aegis1980 Posted March 26, 2010 Share Posted March 26, 2010 looks cool Vascoobiedude. did the same to my GT-B. I did sand it, but being lazy I did not prime it nor mask it at all. Just flicked off shield thing with knife and sprayed whole ting. Stuck it on again after with Aralidite (sp?). has not fallen off yet (15 months later) Paint job looks sweet still, but prob would have come out better with priming? little bit chipped though now. Link to comment Share on other sites More sharing options...
Hurrikane Posted March 27, 2010 Share Posted March 27, 2010 that grill came out really nice.. i was thinking of customizing the standard '98 grill i have, since i can't seem to find aftermarket grills anywhere.. same goes for headlights, wanted to throw on some angel eyes or something of the sort, but can't find a thing for my car any thoughts/suggestions? Link to comment Share on other sites More sharing options...
daleyswanson Posted March 27, 2010 Share Posted March 27, 2010 ^jdm headlights? you wouldn't be able to put angel eyes on the usdm ones Link to comment Share on other sites More sharing options...
kaz98gt Posted March 27, 2010 Share Posted March 27, 2010 +1. the projectors look good. nothing like the halos you're talking about, but much more like them than the us lights. Link to comment Share on other sites More sharing options...
Hurrikane Posted March 27, 2010 Share Posted March 27, 2010 okay thanks for that info daleyswanson.. wasn't sure whether jdm made lights for this car. and kaz, you mentioned projectors? any idea where i can find these? i'm not having much luck with the internet these days haha Link to comment Share on other sites More sharing options...
kaz98gt Posted March 27, 2010 Share Posted March 27, 2010 well that's the jdm headlights for the legacy; it's the projector style headlight. there should be some on ebay right now (in the process of looking for fog light bulbs haha), and that will give you a good idea of what I'm talking about. The subaru projectors are...well...they're projectors no matter how you slice them in my book, but they're not ridiculous or anything. you'll see. Link to comment Share on other sites More sharing options...
daleyswanson Posted April 2, 2010 Share Posted April 2, 2010 jdm just means japanese domestic market, aka alot of cool stuff we never got over here! haha. for our legacies there are a few things that are different between the jdm cars and usdm (us domestic market) such as bumpers, fogs, headlights (jdms are projectors), turn indicators, power folding mirrors, steering wheels... i'm sure there is other stuff i am forgetting. the jdm lights look like deez http://cgi.ebay.com/ebaymotors/JDM-SUBARU-LEGACY-95-98-BG5-PROJECTOR-HEADLIGHTS-OEM_W0QQcmdZViewItemQQhashZitem439e67da4aQQitemZ290420415050QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories Link to comment Share on other sites More sharing options...
Hurrikane Posted April 2, 2010 Share Posted April 2, 2010 okay so i'm a moron, totally thought jdm was a specific company haha.. are the projectors a high quality light compared to the usdm version? would you suggest them? Link to comment Share on other sites More sharing options...
Zues Marine Posted April 2, 2010 Share Posted April 2, 2010 the output of jdm projectors is way better than the usdm reflectors because of the beam pattern, there's a very crisp cutoff line in the projectors, the only thing youll need to do is aim them waay right due to japan being RHD, so you dont blind oncoming traffic Link to comment Share on other sites More sharing options...
daleyswanson Posted April 3, 2010 Share Posted April 3, 2010 i read a diy on changing the lens so it is left hand drive and doesn't blind oncoming traffic. and for what its worth i had to google jdm when i joined the forums. along with a bunch of other lingo, now that i think of it Link to comment Share on other sites More sharing options...
Zues Marine Posted April 3, 2010 Share Posted April 3, 2010 yeah ive seen that one, its too much of a hassle imo, too much risk for a little reward, ha Link to comment Share on other sites More sharing options...
daleyswanson Posted April 3, 2010 Share Posted April 3, 2010 yup. i'd rather just blind people Link to comment Share on other sites More sharing options...
Zues Marine Posted April 3, 2010 Share Posted April 3, 2010 me too, have you seen my front end? > Link to comment Share on other sites More sharing options...
Hurrikane Posted April 4, 2010 Share Posted April 4, 2010 thanks zues, that's very good to know, just ordered a set off ebay XP Link to comment Share on other sites More sharing options...
daleyswanson Posted April 4, 2010 Share Posted April 4, 2010 zues you have the perfect set up to blind people! hahahaha. i'm jealous you ordered some. i'm broke Link to comment Share on other sites More sharing options...
roakleygt Posted April 4, 2010 Share Posted April 4, 2010 Did the same thing to my subaru a few years back. Good solution to an ugly problem. looks way better then chrome anyway. Link to comment Share on other sites More sharing options...
