mixing same tires, but different load rating.
Beanboy
Can you mix same tires minus load rating difference?
Needed two new RE960AS tires, but they are XL versus what I have on the car now. Difference in tread depth is within the 2/32 spec.
On a trip this weekend, will do the string test when I return. If that is within spec, are there any issues with having two tires being a different load rating?
Thanks!
I'm not an expert by any means, but I think if you keep the load under the limit for the lowest number you should be fine. Like how if a 15 amp fuse blows out, you can replace it with a 10 and not have any damage done to the electrical components.
But again, I'm not an expert, so hopefully someone else with more experience can chime in.
It's cool; I'm with the band
