rad.rac3r Posted December 14, 2011 Share Posted December 14, 2011 Did you get the code fixed. Could be a bad OCV. I have been watching your other threads, I dont remeber seeing this code. My turbo finally began to whine and then whistle, when it whistled I replaced it, see my sig. Not yet, but i will pull it out and clean it. Could just be debris from the new rings. I havent had a chance to yet because its at the mechanics. The machinist rebuilding it dident use OEM seals so the camseals are leaking under pressure. When you pulled out the turbo, did you take it apart to see what the issue was? Link to comment Share on other sites More sharing options...
Max Capacity Posted December 14, 2011 Share Posted December 14, 2011 Not yet, but i will pull it out and clean it. Could just be debris from the new rings. I havent had a chance to yet because its at the mechanics. The machinist rebuilding it dident use OEM seals so the camseals are leaking under pressure. When you pulled out the turbo, did you take it apart to see what the issue was? Yes I did, I have pictures here in the "142,000 mile" thread inthe 4th gen forum. The blades are a little bent, very little scrapping in the compressure housing, It had lots of bearing play. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rad.rac3r Posted December 15, 2011 Share Posted December 15, 2011 Yes I did, I have pictures here in the "142,000 mile" thread inthe 4th gen forum. The blades are a little bent, very little scrapping in the compressure housing, It had lots of bearing play. Just went through it, hopefully i dont get to that point; atleast if i do, taking the turbo apart once, i wouldent be as afraid to try and rebuild it if need be. all that was from running it without sufficient oil? Link to comment Share on other sites More sharing options...
Max Capacity Posted December 16, 2011 Share Posted December 16, 2011 I would think so. But the banjo filter didn't look that bad. IMO your better off with out he banjo filter. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rad.rac3r Posted December 17, 2011 Share Posted December 17, 2011 Seems to be the general consensus Link to comment Share on other sites More sharing options...
