ERZperformance Posted March 17, 2010 Share Posted March 17, 2010 Just got one of these in yesterday they are made in Taiwan. here are some picture and specs. http://www.erzperformance.com/v/vspfiles/photos/80140-AM003-HKS-3.jpg http://www.erzperformance.com/v/vspfiles/photos/80140-AM003-HKS-4.jpg http://www.erzperformance.com/v/vspfiles/photos/80140-AM003-HKS-5.jpg In XYZ standard design on shock absorbers in Super Sport (SS), all McPherson struts come with pillow ball upper mounts and Wishbone struts are equipped with aluminum top mounts. The pillowball top mount or aluminum top mount is not available for a few certain applications due to the OE upper mount with no holes on it. PS) The pillow ball top mount is able to adjust camber degree, and to increases stability and handling of your vehicle by 10%. However, the pillow ball might be prone to creating slight amount of noise over big bumps, and this does not cover any warranty. http://www.xyz-racing.com/images/i2.gif Mono-tube design Mono-tube design is adopted for this coilover system as it can retain stable damping and have varieties of response to uneven roads and bumps to keep the comfort. The super sport damper with big piston diameter of 45mm can be used for weekend race as well. http://www.xyz-racing.com/images/i3.gif Fully-adjustable lower mount A moveable bottom mount is adopted; both ride-height and pre-load can be adjusted by adjusting the bottom mount. Use of aluminum material enables to reduce weight. http://www.xyz-racing.com/images/i4.gif Damping adjustable Super sport damper has 30-way damping settings to bring the best performance for different road conditions. The shock uses needle valve to have linear damping adjustment at each level. http://www.xyz-racing.com/images/i5.gif Anti-rust All threaded parts are coated with Fluorine to prevent corrosion or adherence. A bottom mount is anodized. http://www.xyz-racing.com/images/i6.gif Coil spring 99% applications come with pillow ball upper mount to enable you to experience the driving feel directly. Super Sport damper is equipped with the springs that have the most perfect spring rates. http://www.xyz-racing.com/images/i7.gif Aluminum bottom mount Lightweight aluminum bottom mount is used to reduce the weight and to have ability to dissipate heat. http://www.xyz-racing.com/images/i8.gif Spring bearing The piece put between the spring and the locking ring is Teflon bearing, it can eliminate strange noises and allow a vehicle to move more smoothly when turning. Link to comment Share on other sites More sharing options...
Bolksey85 Posted March 17, 2010 Share Posted March 17, 2010 Spring rates? And is it safe to assume these are comparable to Megans? Link to comment Share on other sites More sharing options...
m sprank Posted March 17, 2010 Share Posted March 17, 2010 Please (at least) say they are better than Megans. Look like maybe ksport/d2? Look decent. Price? Might be an option for those looking to not break the bank. Link to comment Share on other sites More sharing options...
ERZperformance Posted March 17, 2010 Author Share Posted March 17, 2010 The spring of Subaru Legacy BP5/BL5 (05-UP) front is 9kg/mm and rear is 9kg/mm. Thank you. Link to comment Share on other sites More sharing options...
Bolksey85 Posted March 17, 2010 Share Posted March 17, 2010 Wow, I didn't think they would be that highly sprung. Interesting.... Link to comment Share on other sites More sharing options...
SubyShop.com Posted March 17, 2010 Share Posted March 17, 2010 Look like rebadged KSports but the Teflon bearing sounds like a cool concept. Is it possible to get custom spring rates (stiffer rear)? -Franz Link to comment Share on other sites More sharing options...
wcbjr Posted March 17, 2010 Share Posted March 17, 2010 I'd like that Teflon. I get a bit of squeeking from one of my BC coilovers. I forgot what I was supposed to remember. Link to comment Share on other sites More sharing options...
Mindspin311 Posted March 17, 2010 Share Posted March 17, 2010 Teflon bearing would have been nice on my set of Stance's on my FC RX7. When I first got them, the pillow ball's were so tight, the springs bound up, then popped back in place any time I turned the wheel. Link to comment Share on other sites More sharing options...
marios13 Posted May 19, 2010 Share Posted May 19, 2010 Revhartvideos.com did a product review, check it out XYZ COIL OVER SUSPENSION REVIEW on Vimeo Link to comment Share on other sites More sharing options...
katalyst Posted May 19, 2010 Share Posted May 19, 2010 looks promising i like how the lower mount is anodized Link to comment Share on other sites More sharing options...
ERZperformance Posted May 20, 2010 Author Share Posted May 20, 2010 I got one set anyone want to take it home for 650 shipped Link to comment Share on other sites More sharing options...
marios13 Posted May 20, 2010 Share Posted May 20, 2010 Any input Link to comment Share on other sites More sharing options...
