lieutenantcolumbo Posted March 26, 2010 Share Posted March 26, 2010 jproy12, I have the same wheels and run 245/35/18 eagle f1 gsd3's. The 245/35 is the closest to stock size so the speedo is not off. Just wondering if your car is lowered at all, what type of shocks you're using, whether you had to get the fenders rolled, and if you have any rubbing. I like the idea of keeping the stock diameter, but I'm concerned about how wide they are. Thanks! Link to comment Share on other sites More sharing options...
suds2250 Posted March 26, 2010 Share Posted March 26, 2010 I'm on JDM Spec B Bilstiens with prova springs. No rub, no roll. 335HP/360Tq VF-22/1820 clone with Meth Link to comment Share on other sites More sharing options...
lieutenantcolumbo Posted March 28, 2010 Share Posted March 28, 2010 I'm on JDM Spec B Bilstiens with prova springs. No rub, no roll. Thanks, I may go that route then. I'd like to get a dedicated set for summer fun and keep my stock rims for snow tires. That's got to be a blast to drive (unless it rains). Link to comment Share on other sites More sharing options...
TSiWRX Posted March 28, 2010 Share Posted March 28, 2010 I went with 225/40 on 18x8 but I'm starting to think 235/40 might have been a better choice. Just not much sidewall to protect my pretty Prodrives. Especially this time of year with potholes opening up like crazy. Overall diameter is less than stock Spec B. In reality 235 is not much bigger sidewalk than 225. Just drive slowly over the pot holes and you'll be fine ^ Yep, it's not that much more sidewall protection, but one thing I would have appreciated would be more rim protection, period. The 225s I have (and this will depend on the specific tire), Hankook RS-2s, seem to be stretched ever so slightly at that rim width. Don't get me wrong, I love the way it feels - if I even think about changing directions, the car does it. But rim damage does become a harsh reality (and it's why I bought my Prodrives second-hand, they were pre-rash'ed to minimize heartache! ). jproy12, I have the same wheels and run 245/35/18 eagle f1 gsd3's. The 245/35 is the closest to stock size so the speedo is not off. ^ This was my leading alternative sizing, but I was worried about increased carcass weight, as well as added expense. I also feared the extra width diluting some of that razor's edge response I'd been so used to (my previous set of summers was a 225-width, too). I think I'll go that route this time around, though. Might as well give it a try! <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
wpgspecb Posted April 20, 2010 Share Posted April 20, 2010 Envoy moi un PM.. est-ce que tu es sur le club Subaru de Montreal ou d'Ottawa? Now would 235/40 rub on the perch of the strut? JP if you go +55 or less you will actually have MORE clearance around the strut than stock 235/40/18 on 18x7.5 wheels with +42 offset 2008 spec b rub on left rear with factory shock (40,000kms) no rub on right rear (new shock 5000km ago) my thread here http://legacygt.com/forums/showthread.php/velox-javlin-j-2-18x7-135930.html Link to comment Share on other sites More sharing options...
wpgspecb Posted April 20, 2010 Share Posted April 20, 2010 Check this out , i am running 235/40/18 BUT i am running coilover , it didn't rub the fender http://i174.photobucket.com/albums/w90/kaho8930/IMG_0452.jpg http://i174.photobucket.com/albums/w90/kaho8930/IMG_0455.jpg http://i174.photobucket.com/albums/w90/kaho8930/IMG_0453.jpg what offset Link to comment Share on other sites More sharing options...
Bonafide P Posted January 15, 2015 Share Posted January 15, 2015 Trying to find out what tires fit well with no rolling fenders and no rubbing, I'm slightly lowered on kybs and ralliteks. Which is a inch all round, 18x8 et 48 will 235 40 18 fit? Thanks in advance. Link to comment Share on other sites More sharing options...
Drift Motion Posted January 15, 2015 Share Posted January 15, 2015 why not 245/35/18? Link to comment Share on other sites More sharing options...
Bonafide P Posted January 16, 2015 Share Posted January 16, 2015 why not 245/35/18? In not sure what would fit best. Would that work too? I'm trying to make it fit without rolling the fender or having rubbing issues. Thanks for your input. Link to comment Share on other sites More sharing options...
jcdennis Posted January 19, 2015 Share Posted January 19, 2015 In not sure what would fit best. Would that work too? I'm trying to make it fit without rolling the fender or having rubbing issues. Thanks for your input. I posted here (4 years ago - wow time flies) about my experience with 235/40. Same offset. No rubbing on a slight drop (had to remove the rubber strip though). Link to comment Share on other sites More sharing options...
Bonafide P Posted January 21, 2015 Share Posted January 21, 2015 I posted here (4 years ago - wow time flies) about my experience with 235/40. Same offset. No rubbing on a slight drop (had to remove the rubber strip though). Ohh sweett, thanks for tip. Going with 235s! Link to comment Share on other sites More sharing options...
